Home > Technical > Scuffed bumper
Timf
United Kingdom 2010 Range Rover Sport TDV8 HSE Galway Green
Scuffed bumper
Hi all,
Dont think previous message got thru - apologies if this is a repeat...
Can I lightly sand & aerosol spray a scuffed bumper corner or is it a pro job? It looks as if there is a lacquer covering the paint..??
Many thanks
Tim
Post #262494 Fri Apr 09 2010 8:02am
funnyguy1
United States 2009 Range Rover Sport 4.4 V8 HSE Santorini Black
The front and rear bumpers are sprayed with a special primer/paint that has a elastic polymer in it.
You may want to check with your local paint shop before attempting. Good luck! mike murphy
Post #262596 Fri Apr 09 2010 10:06pm
Timf
Many thanks - I wont be trying it! Whistle
Post #262622 Sat Apr 10 2010 9:20am
Jarvis
Just had mine fixed by a local auto body shop for a couple hundred bucks. The parking sensor mount was broken as well, and so the sensor was replaced. Total of $400 (US). Can't even tell anything happened now.
http://www.smugmug.com/photos/820649392_Rr38j-L.jpg
(And no, the scofflaw who did it did not leave a note.)
Post #262642 Sat Apr 10 2010 2:18pm
Timf
Similar damage jarvis - thanks - will investigate my local airbrusher Thumbs Up
Post #262676 Sat Apr 10 2010 8:12pm
Jarvis
Worth noting that the invoice did reflect a "flexible ealstic" add-in to the paint, both of which were OEM from RR.
Post #262701 Sun Apr 11 2010 7:05am
