![]() | Home > Technical > HDC Fault & Flat Battery |
wildwolfnw Member Since: 23 Jan 2009 Location: Blackburn Lancs Posts: 5 ![]() ![]() ![]() |
About 3 months ago i started geting HDC fault,special programmes off on start up but never realy paid it any attention as it was working and i didnt get it again until the first start up of the day. 3 weeks back came to start it up and nothing,battery was as flat as a pancake. The aa came out jump started it, tested the battery and said its fine,no problems with it i must have left a light on inside or some thing. Vechiles been fine since although still geting the HDC fault on the first start up of the day,then yesterday flat battery again. aa came out jumped it and tested the battery again, no problem with the battery but then after a few minutes he tested again and said its over chargeing,should be 13 to 14 (some thing) and it was chargeing at 15.4 he said i probably need a new alternator.
PauloAmore Member Since: 27 Jan 2007 Location: Bonnie Scotland Posts: 1292 ![]() ![]() |
New battery +1 2022 P440e AB |
MAW Member Since: 06 May 2006 Location: Lincs Posts: 3104 ![]() ![]() ![]() |
Battery |
DSL Member Since: 17 May 2006 Location: Heelands/Cobham (delete as appropriate) Posts: 1045 ![]() ![]() |
If still in warranty then should be covered, if over 3 years then new battery is �104 with allegance discount. Plus the new battery has a 3 year warranty. Make sure you get the new type as below (LR number) even though it has YG ����130 on the battery itself.
Assuming the D3 battery is same as yours that is. ![]() |
rrs2010 Member Since: 10 Feb 2010 Location: Leicestershire. Posts: 173 ![]() ![]() ![]() |
I was having the same HDC message every morning... New battery solved it |
cleeto27 Member Since: 06 Jan 2008 Location: Portugal Posts: 83 ![]() ![]() ![]() |
My alternator packed up a week ago after 115000 fault free miles |
