Home > Maintenance & Modifications > Replacing Shock Absorbers |
NickM Member Since: 14 Feb 2008 Location: London Posts: 2995 |
Who says they have shocks???? i thought they had air suspension!!! |
Mon Apr 05 2010 6:30pm |
lespes Member Since: 16 Jun 2008 Location: Channel Islands Posts: 1052 |
If you are meaning the airbag then buy new with strut fitted, slightly more expensive than without the strut but worth it for less time and agro in fitting |
Mon Apr 05 2010 7:03pm |
marvelaugusts Member Since: 02 Apr 2010 Location: uk Posts: 4 |
Hello guys, If there is a 'leakage in your suspension', it would be from the shock absorbers, which should logically then be replaced. I can't think of one reason why you'd need to replace the entire suspension. m3 card |
Tue Apr 06 2010 4:47am |
Thu Apr 08 2010 2:28am |
