Home > Technical > when replace the ball joint
iz6byo
2006 Range Rover Sport TDV6 HSE Buckingham Blue
hi to all....
i have a question...
i saw here,and on the disco3 forum many topics for replace the ball joint.
i have a little problem when turn my steering after i have broken.
for example if i stop and go in reverse gear, turning, i have a noise,fell on steering,
like a "metallic crash"
i saw this problem with my technician but without solve Sad
is it possible comes from the ball joint????
thanks in advance Bow down
Post #261826 Fri Apr 02 2010 5:41pm
iz6byo
nobody?????? Sad
Post #262217 Tue Apr 06 2010 9:56pm
LotusPosition
Hi There
I've had a similar symptom, and a couple of dealers had been unable to repeat the issue under testing, so were unable to suggest a fix. A third dealer at the point of MOT’ing the RRS spotted the problem and diagnosed is as being the ball joints. You might have a different issue to me, but certainly sounds similar. When the ball joints were changed the issue completely disappeared. Smile
LP
Post #262445 Thu Apr 08 2010 7:46pm
iz6byo
wowwwww Bow down
thanks so much for this....... Very Happy
i'll buy quickly a new pair of them for replace....
i'll come back soon for any news.....
thanks again
Post #262598 Fri Apr 09 2010 10:22pm
Vadim
United Kingdom 2010 Range Rover Sport Supercharged Santorini Black
any luck? Vadim A.
Post #264113 Sun Apr 25 2010 12:07am
