Home > Technical > Rain Sensing variable wiper control - how does it work?
twozzie
United States 2006 Range Rover Sport 4.4 V8 HSE Bonatti Grey
Can someone advise how the variable part of the control on the wiper stalk work? The owners manual is about as much use as a chocolate teapot. It says it allows you to vary the rate - great, but no matter which direction I adjust it, it doesn't make a difference. Does moving it toward the narrow end of the "logo" means there is less time between wiper sweeps or does does it mean less frequency of sweeps? Am I making sense?
I guess I could ask the stealer as the damn car is always in there anyway for one thing or another.
Post #261541 Tue Mar 30 2010 7:04pm
Bradders
Doesnt seem to make any difference on my TDV8 either. Confused FF 4.4 V8 Soooo looking forward to this bad boy
Ex 2006 RRS SC - garbage
Ex 2016 135i M Sport - dream car
Ex 2003 RS6 Avant - piece of cr*p
Ex 2014 320d X Drive, M Sport Touring - ok I guess
Ex 2007 RRS TDV8 - bloody loved it
EX 2007 FL2 XS - not so bad
Post #261552 Tue Mar 30 2010 8:24pm
Landlord
United Kingdom 2010 Range Rover Sport 3.0 TDV6 HSE Alaska White
For years I thought it was just me who didnt know !
The new 10MY has fast and slow on the stalk as well as the logo to help. MY10 TDV6 HSE, Alaska White, Ebony with Contrast, Park Heat, Paddle Shift, Privacy, Heated Steering Wheel, Extended & Premium Leather,
MY07 TDV6 HSE, Zermatt Silver, Gone
1964 Austin Healey 3000
2007 LR Defender
2011 VW Tiguan R Line
Post #261553 Tue Mar 30 2010 8:28pm
NightFox
Supposedly it adjusts the sensitivity of the sensors - I've yet to be convinced of that though. Alfa Romeo Giulietta 1.8::MG Montego Turbo::MGB GT::Rover Sterling::MGF::MG ZT 190+
Discovery Series II Td5 GS::Discovery 3 TDV6 S::Freelander 2 TD4 XS::Freelander 2 TD4 SE
Zermatt Silver Range Rover Sport TDV6 3.0
Post #261564 Tue Mar 30 2010 9:08pm
Endjin
Scotland
On my 2010 model there does seem to be a difference in sensitivity but really only between the Top & Bottom settings. All the settings in between do nothing! But Hey C'mon..... It's a Rangie..... It'd be boring without all it's.... Ummm.. "features"! Confused Whistle Mr. Green 2013 Discovery HSE Luxury - 3.0 SDV6 - Santorini Black
2013 Evoque 5 Door Pure Tech SD4 - Orkney Grey with Panoramic Roof (Mrs E's new baby)
GONE - RRS - 3.0 TDV6 HSE - Santorini (2010)
GONE - RRS - 2.7 TDV6 HSE - Java Black (2007)
GONE - Porsche Boxster S - 3.2 - Black
Post #261565 Tue Mar 30 2010 9:20pm
Bob.
My manual says "You can increase or decrease the sensitivity of the rain sensor, and therefore the frequency of wiper operation, by rotating the delay switch either clockwise or anticlockwise."
From my experience it does make a slight difference to wipe rate between max and min settings but it is too little difference to be of any practical use.
Post #261581 Tue Mar 30 2010 10:42pm
Bobby
It's also vehicle speed dependent.
Quote:
The rain/light sensor is active when the wiper column control switch is in the intermittent position. The rain/light sensor suspends wiper operation when the area of the windshield for the rain/light sensor is dry and operates the wipers continuously when the windshield is subject to heavy rainfall.
By using the intermittent rotary switch on the wiper stalk the driver can adjust the sensitivity of the rain/light sensor. Six sensitivity levels of the sensor can be selected, which has the effect of increasing or decreasing the wiper delay period, allowing driver adjustment for the prevailing conditions. When several continuous wipe cycles have taken place, the sensor will maintain the continuous operation to avoid switching back to intermittent from a continuous wipe and back again.
The rain/light sensor receives vehicle speed information from the Anti-lock Braking System (ABS) module on the Local Interconnect Network (LIN) bus via the CJB. The sensor increases the sensitivity as the speed increases to optimise wiper operation. When the vehicle speed is reduced to less than 5 mph (8 km/h), the sensitivity is automatically reduced. Below this speed the wipers will only operate continuously in very heavy rain.
 Malaysia Boleh!
4.2SC Chawton White, Stormers
Clear Side Repeaters, Towbar
Post #261587 Wed Mar 31 2010 12:05am
twozzie
I'm with Ya but........
Ok, I'm with ya on this but which direction is the more sensitive, Pointy end or Wide end of logo?
Post #261590 Wed Mar 31 2010 2:15am
al zheimers
Wales 2007 Range Rover Sport TDV6 HSE Stornoway Grey
According to my dealer who I asked the same question - The wider the bar, the more sensitive
Post #261597 Wed Mar 31 2010 7:35am
RichardM
2010 Range Rover Sport TDV8 HSE Galway Green
I've found mine works really well, more it to the top to be most sensitive. WINNER - 2009 ‘Just Doing What It’s Designed To Do’ Award
2010 TDV8 HSE Galway Green - Adaptive Cruise - Sunroof - Privacy Glass - 5 Spoke Alloys
2009 TDV6 3.0 HSE Buckingham Blue - GONE
Post #261600 Wed Mar 31 2010 8:00am
umbertob
United States 2006 Range Rover Sport 4.4 V8 HSE Chawton White
Adjusting the sensitivity on the wiper stalk seems to make a substantial difference mostly on the frequency of the REAR wiper operation. For the front wipers, it makes an almost insignificant difference, usually you can confirm it if you are stopped at a red light and under a light drizzle. Under the least sensitive position, the front wipers pretty much don't move until the car starts moving again. If you flip the knob to the most "sensitive" position, the wipers activate even while stationary every few seconds... But once you are moving, I don't see any difference, the sensor has a mind of its own.
Post #261624 Wed Mar 31 2010 4:01pm
ViewWise
ok never read the manual but i know it makes a difference since i use it alot.
Ive found the key thing to remember is when you have the REAR wiper ON the stalk only changes the speed of the rear wiper. Turn the rear wiper off to adjust speed of front wipers.
Not sure which ones the wider bar since never looked but i know if i rotate the stalk upwards (so the plastic lip gets away from me) it gets more sensitive.
Thumbs Up WINNER - 2008 Best All New Photograph
WINNER - 2009 Best All New Photograph
Post #261655 Wed Mar 31 2010 10:17pm
purple people eater
ViewWise wrote:
Ive found the key thing to remember is when you have the REAR wiper ON the stalk only changes the speed of the rear wiper. Turn the rear wiper off to adjust speed of front wipers.Thumbs Up
ah, it makes more sense to me now, should have read the manual Thumbs Up purple people eater
There are no good days, just some days that are not as bad as others!
Gone RR 4.0 P38 Autobiography MY99 Red ( Evil or Very Mad money pit)
Gone Big Cry RRS MY06 2.7TDV6 HSE Rimini Red
Gone RRS MY10 3.0TDV6 HSE Bali Blue with lots of bits (never grew to love it)
Here Now - 3.6 TDV8 FFRR OVERFINCH Stornoway Grey - loving it x
My work car Ford Mondeo 2.0 TDci Zetec auto Estate in Silver
Post #261670 Thu Apr 01 2010 7:55am
RichardM
I've never found that on my MY10. It always adjusts the front. The manual states:
Move the wiper switch to position 1. The wipers will operate for a single wipe and then the interval between subsequent wipes is controlled by the rain sensor. The rain sensor detects the presence and amount of rain/dirt/snow on the windscreen and operates the wipers as required. Rotate the collar clockwise to increase or counterclockwise to decrease the sensitivity of the rain sensor and therefore the frequency of wiper operation.
Note: Increasing the wiper sensitivity will operate the front wipers for a single wipe.
For the rear wiper it states
Wiper - intermittent operation
Pull the lever backwards to position 1. The intermittent delay period will vary according to vehicle speed.
Wiper - continuous operation
The rear wiper can be configured to operate continuously.
This setting can be configured by a Land Rover Dealer/Authorised Repairer.
Nothing about the dial adjusting the rear wiper! WINNER - 2009 ‘Just Doing What It’s Designed To Do’ Award
Post #261673 Thu Apr 01 2010 8:45am
Bobby
Re: I'm with Ya but........
Does this point you in the right direction?
 Malaysia Boleh!
Post #261772 Thu Apr 01 2010 11:18pm
