Home > General > Car in low power mode ? |
jackt Member Since: 21 Nov 2005 Location: New Jersey Posts: 11 |
Hello dellis, your best bet is to do a couple of resets, ei put the key fob turn it in order to do the self check befor you start the car. I happened to me 2-3 times so far with 7.5k miles. I don't have the integrated phone, but the Sat Nav was on after i took out the key. I did 2-3 times the reset and corrected it self. if with so many electronics we have only this problem we are blessed.. I remember my fathers car (69 Singer,,!) had only 3 fuses. If something was wrong he was changing all 3 and done... |
Thu Apr 20 2006 7:05pm |
grommet Member Since: 28 May 2005 Location: Northern California Posts: 299 |
Low power mode is used for all infotainment electronics when your engine is off and you are trying to use it. Also, the infotainment system doesn't immediately turn off. This is by design.
Thu Apr 20 2006 7:54pm |
Supertrotter Member Since: 10 Mar 2006 Location: Brrrr.... guess where :o( Posts: 9905 |
Dellis, my car displays the low power mode if I switch the engine off with anything like iPod/phone/PSP cahrging in lighter socket.
Sat Apr 22 2006 9:35am |
