Home > Technical > Acceleration cut off when reach 30mph |
Leo Member Since: 17 Sep 2007 Location: Nomad Posts: 554 |
Are there any warning lights illuminated or messages displayed?
Sat Mar 27 2010 10:11pm |
purple people eater Member Since: 10 Dec 2009 Location: Miles beyond midlife crisis Posts: 990 |
are you towing a caravan? purple people eater
Sat Mar 27 2010 10:17pm |
fayodeji Member Since: 27 Mar 2010 Location: Nigeria Posts: 4 |
There is no warning lights illuminated or messages displayed. But when I did a "QUICK TEST (FULL VEHICLE FAULT READ)" on Autologic Diagnostic tool, I found a new fault (not sure they were there before or after the speed limit issue) as below:
Sun Mar 28 2010 12:59pm |
Texstar Member Since: 27 Aug 2006 Location: W.London Posts: 208 |
Ignore the HVAC fault codes, most RRS's and D3's have these. I don't get the clutch fault code though, I would have thought that would apply to a car with a MANUAL gearbox. Does the gearbox stay only in a low gear? ie does not change up through the gears as it should. RRS TDV8 Buck Blue (no, not now in my dreams). ..........D3 TDclankety clankV6 ............BMW 318i |
Sun Mar 28 2010 1:48pm |
It stay on 4th gear when it reach 30mph. |
Sun Mar 28 2010 3:13pm |
avos Member Since: 26 Aug 2008 Location: Belgium Posts: 106 |
P0806-00 Description
Sun Mar 28 2010 3:52pm |
Avos, thanks for the info. You mentioned "or by the procedure listed in the description and operation. Refer to the relevant section of the workshop manual. ". Where can I find this procedure? |
Sun Mar 28 2010 4:40pm |
Not sure if you have access to an IDS, but If so, the new SDD (Symptom Driven Diagnostics) software on the IDS may lead you to the menu option either via the DTC or via selection of the area you want to investigate (rear axle/diff). However this SDD is relatively new, and may not work flawlessly yet.
Sun Mar 28 2010 5:09pm |
