![]() | Home > Technical > Vista sheet |
Lookers Park Royal Member Since: 15 Nov 2007 Location: London Posts: 2303 ![]() |
FBH is an aux fuel burning heater that cuts in at less than 4deg to help heat the vehicles cooling system/engine quicker as diesels take a while to heat up. This isn't Remote Park Heating which is a remote to activate the FBH. Not sure if you will have a FBH on a B spec?
quantz Member Since: 05 Mar 2010 Location: Paris, France Posts: 476 ![]() ![]() |
Thank you James.
It is being built to Belgium spec hence the B! |
[quote="Lookers Park Royal"] Not sure if you will have a FBH on a B spec?
