Home > Technical > One touch window closers.
BIG DJ
If you don't have the one touch window is it a case of just fitting different switches or is there more to it?
Post #260638 Tue Mar 23 2010 5:13pm
rrs2010
It's in the manual Thumbs Up
I enabled mine, All I did was hold the 'up switch' up for 2 seconds with the drivers window in the closed position and the ignition on Very Happy Cheers Paul
2006 TDV6 HSE - Cairns Blue
Tow Pack, Privacy Glass, PTI, DVD.
Post #260777 Wed Mar 24 2010 4:06pm
BIG DJ
Cheers Thumbs Up
I thought it was an optional extra on early hse's?
Post #260779 Wed Mar 24 2010 4:45pm
Tweaky
I think you will find it is only standard on MY56 cars
Post #260793 Wed Mar 24 2010 7:15pm
BIG DJ
That's what I thought!
What is different tho? Is it just the switches or wiring or motors different?
Post #260794 Wed Mar 24 2010 7:32pm
Tweaky
I would think that the switches are different as when i push mine to lower the window i fit a point of resistance, push beyond that and the one touch function kicks in. I expect that it is a different switch and relay system, but couldn't say for sure as this is not my field of expertise.
Post #260888 Thu Mar 25 2010 1:18pm
