Home > Technical > Split turbo hose and oil seepage
redrover
Australia 2007 Range Rover Sport TDV6 HSE Java Black
Hi All,
After suffering low power, much smoke and an engine fault warning, I decided to go old school and open the bonnet for a look. There was a 3cm split at the top of the large turbo hose between the intercooler and throttle body. I pulled this off for a temporary repair (as I couldn't get into a dealer for a week!) and found quite a bit of oil seepage from the split as well as at the bottom of the hose. Is this normal? I would of thought clean air goes through here or is this something to do with the egr? It is just under warranty so I want to make sure nothing is missed...
thanks,
Anthony TDV6, MYO7 Java with Ivory leather, 19 inch wheels
Post #260229 Sat Mar 20 2010 2:57am
