Home > Technical > Memory seat problem |
grommet Member Since: 28 May 2005 Location: Northern California Posts: 299 |
The memory is key fob specific. When you set/save your positions and pull out the key... the "lazy entry" memory (seat, mirror & mirror dip) is saved for your specific key. |
Wed Apr 19 2006 5:46pm |
umbertob Member Since: 22 Sep 2005 Location: Pasadena, CA Posts: 944 |
Why don't you try setting your wife's seat position to Memory 1 (with her key in the ignition and Lazy Entry on), then do it all over again with your own key in the ignition, setting Memory 1 to your own seat position? By doing it that way, in theory you would never have to fiddle with the other memory buttons (2 and 3), which could create problems if you mistakenly pressed the "Memory Store" button instead of the 1,2, or 3 button, I have done that many times...
Wed Apr 19 2006 5:51pm |
jackt Member Since: 21 Nov 2005 Location: New Jersey Posts: 11 |
Thanks Grommet, the problem is that only my wifes key fob seems to work with the lazy entry. i'll set ip up to on as well using my key to see what happens.
Wed Apr 19 2006 6:11pm |
Because, like grommet said, each memory is keyfob-specific. With Lazy Entry enabled, it's as if you had 6 memory positions, 3 assigned to the first keyfob, 3 to the second. If you want to keep doing it the old fashioned way (enabling Memory 1 for your preference and Memory 2 for your wife's, regardless of which key you use), you should turn off lazy entry. |
Wed Apr 19 2006 6:18pm |
Umbertob now is more clear, it makes sence. I had an Acura TL and had the same setup but no problems. The key fob was linked to each memory seat (had only 2) with lazy entry. You could setup which key to link with which memory seat. I guess you have more choises with the RRS which makes thinks a little more complicated. thanks for the advice, its the first think i'll do tonight... |
Wed Apr 19 2006 6:26pm |
