![]() | Home > Technical > WON'T COME OUT OF PARK !!! |
Texstar Member Since: 27 Aug 2006 Location: W.London Posts: 208 ![]() ![]() |
You are pressing the brake pedal when you try this, aren't you?as it has an interlock. Or if you are on a slope, the park pin may be under some load. so will be stiff to move lever. RRS TDV8 Buck Blue (no, not now in my dreams). ..........D3 TDclankety clankV6 ............BMW 318i |
feg355 Member Since: 09 Mar 2010 Location: north wales Posts: 2 ![]() ![]() |
yes footbrake is pressed but it is on a slight incline. Do you think if i get some able bodies to push fron front it might release! |
Yep,it should do,but you'll obviously have to leave the foot off the brake, til your very burly helpers |
Start your engine, place your hand on the gear selector lever and apply the foot brakes.
Misery Member Since: 07 Dec 2005 Location: Waiting for L405 Posts: 2555 ![]() ![]() |
Once again THANK YOU BOBBY. |
