Home > Technical > Paddle Shifters in Drive
NightFox
Wow, I'm just full of questions today...
Do the paddle shifters on the steering wheel work when you've got the gearbox in "D", or only when you knock it over to "S" or Command Shift?
If they do work in "D", does it keep changing the gear back into what it thinks it should be rather than what you want it to be, or does it stay in the gear you've selected with the paddles until it needs to change, like it does in Command Shift mode? Alfa Romeo Giulietta 1.8::MG Montego Turbo::MGB GT::Rover Sterling::MGF::MG ZT 190+
Discovery Series II Td5 GS::Discovery 3 TDV6 S::Freelander 2 TD4 XS::Freelander 2 TD4 SE
Zermatt Silver Range Rover Sport TDV6 3.0
Post #257973 Wed Mar 03 2010 12:49pm
Jimmy_75000
Re: Paddle Shifters in Drive
They do work in D and "does stay in the gear you've selected with the paddles until it needs to change".
Also, if you stay and the same speed for a short minute while in "paddle" mode...it will revert into normal D drive. Range Rover Vogue ‘17 TDV6
Gone: Range Rover Vogue '11 4.4TDV8, Range Rover Sport ‘59, Range Rover Sport ‘56
Post #258003 Wed Mar 03 2010 2:45pm
NightFox
OK, thanks, so just to get this straight...
If I'm tootling along at 30mph with the gearbox in D using 3rd but I want to be in 4th I can change with a quick flap. Unless the speed drops too low, the gearbox will stay in 4th even though I've still got D selected. Am I right?
But when you say that "if you stay and the same speed for a short minute while in "paddle" mode...it will revert into normal D drive" do you mean that if I carry on in 4th at 30mph, after a minute or so it will take control again and put me back into 3rd?
P.S. What's your view (no pun intended) on the camera system and the auto-main beam thingy? Alfa Romeo Giulietta 1.8::MG Montego Turbo::MGB GT::Rover Sterling::MGF::MG ZT 190+
Post #258007 Wed Mar 03 2010 3:23pm
