![]() | Home > General > Fuel Economy - Auto or Command Shift? |
When using Command Shift you don't get the 6th gear, so you would have to knock into auto when cruising. That's either an issue or not, depending on your personal preference obviously |
NightFox Member Since: 02 Mar 2010 Location: North Shropshire Posts: 381 ![]() ![]() |
Really? I had a test drive yesterday and am sure I could put it into 6th. I guess it might not auto-shift up to 6th when you're in "S" mode, but I'm (almost) positive I manually upshifted to 6th.
You're right - doesn't auto shift |
Alicatt Member Since: 11 Jun 2007 Location: Eating in Eksel or Ice cold in Alex Posts: 1435 ![]() ![]() ![]() |
it will if you go fast enough |
Bradders Member Since: 08 Oct 2009 Location: Leeds Posts: 2515 ![]() ![]() |
I'm pretty sure you can get it into 6th at about 40mph in Command Shift. Auto does tend to hang onto lower gears more so I guess its using more fuel as the engine is at higher revs for the same road speed? FF 4.4 V8 Soooo looking forward to this bad boy
70km/h is as slow as it will change up to 6th in command shift on my car, on the nice flat roads around here that equates to a fuel consumption of 7.2l/100km (39mpg) |
On a flat straight road in my manual FL2 I'd tend to go for 4th @ 30mph, 5th @ 40mph and 6th @ 60mph. The FL2 auto box tended to leave the change till about 10mph more than I did, even under gentle acceleration. I know the auto box is supposed to adjust to your driving style, but I can't see it changing as low as I do - I guess it doesn't know the road ahead so always tries to keep some performance in hand in whatever gear it's in. During my RRS test drive, I tried changing at the same sorts of speed and the engine didn't seem to have a problem (test drive was in a TDV8 though), but don't know if it would have made much difference to the fuel economy compared to just leaving it in full-auto. Also, it's odd but although I drive a manual at the moment, driving an auto like this with Command Shift I have to keep reminding myself to change gear (yes, I know I don't need to but when I'm trying to use the gears manually) Alfa Romeo Giulietta 1.8::MG Montego Turbo::MGB GT::Rover Sterling::MGF::MG ZT 190+ Discovery Series II Td5 GS::Discovery 3 TDV6 S::Freelander 2 TD4 XS::Freelander 2 TD4 SE ![]() Last edited by NightFox on Wed Mar 03 2010 12:35pm. Edited 5 times in total |
mercuryl Member Since: 07 Oct 2008 Location: Sussex Posts: 195 ![]() ![]() ![]() |
I use the sport mode thing a lot - when you push the stick to the left from normal auto mode.
gordon kerr Member Since: 14 Jan 2010 Location: Bedford Posts: 49 ![]() ![]() ![]() |
[quote="mercuryl.... unless that is, there's something wrong with my mileage computer thingy![/quote]
In both the P38 Range Rover I had before and the 2.7 TDv6 Sport I have now the "mileage computer thingy" had been hopelessly over optimistic with the figures it produces compared to manual caluclations. Don't believe a word it says. IME you need to take 2-3 mpg off it every time.[/quote] Lol - mine is reading 23.8mpg. Just filled up today and I'm getting 18!!! ![]() ![]() ![]() Ex 2006 RRS SC - garbage Ex 2016 135i M Sport - dream car Ex 2003 RS6 Avant - piece of cr*p Ex 2014 320d X Drive, M Sport Touring - ok I guess Ex 2007 RRS TDV8 - bloody loved it EX 2007 FL2 XS - not so bad |
ASH555 Member Since: 02 Dec 2006 Location: East Yorkshire Posts: 750 ![]() ![]() ![]() |
Didn't we have the command shift 6th gear will/won't thing last year? MY10 3.0 TDV6 HSE, Zermatt Silver, 20" Diamond Turned Alloys, Factory Privacy Glass, Premium Leather, Contrast Stiching, Side Steps, Etc
dazsear Member Since: 23 Nov 2008 Location: Lincolnshire Posts: 851 ![]() ![]() |
I seem to think you can almost 'programme' the auto box to drive to your style.
lespes Member Since: 16 Jun 2008 Location: Channel Islands Posts: 1052 ![]() ![]() ![]() |
Had a 150 mile trip each way yesterday.
