Home > General > How best to use a TDV Engine for short trips? |
lespes Member Since: 16 Jun 2008 Location: Channel Islands Posts: 1052 |
Fuel consumption will be poor, but would think little effect in the long term.
Fri Feb 26 2010 11:23am |
I don't know if the service indicator is triggered by use or if it is only elapsed time/miles but you may find you have it flag up that a service is due more often too with that sort of use. Best thing would be to avoid using the car on really cold days for such a short trip. Honestly you really should consider a used S/C as gasoline engines warm up much more quickly than diesels and, especially in cold weather, the TD will trigger the Fuel Burning Heater which the S/C doesn't need and which uses even more fuel.
Fri Feb 26 2010 11:29am |
Aff Member Since: 25 Feb 2010 Location: Suffolk Posts: 11 |
Fuel consumption is not a major issue as I'm not expecting great things from a V8 and I will also be doing motorway miles at least once a week.
Fri Feb 26 2010 11:31am |
flydive Member Since: 16 May 2007 Location: South Posts: 1213 |
As Tim said, if you have DPF it might fill up quickly
Fri Feb 26 2010 11:35am |
If your Audi handled the same treatment without any problems then your RRS will too! Fuel consumption on the TDv8 is quite reasonable, town drivers seem to get 20-24mpg on longer trips anything between 26 and 34mpg depending on how you drive and length of trip - I'm getting 26-28 mpg on fast A roads, with no commuting and 32-34 on long haul runs (200 miles + and using the cruise control) on my longest trips (Central Scotland to Southampton 2-3 times a year) I can get 33mpg easily when the car is on it's normal 20" summer tyres, currently I'm on 19" Snow and Ice tyres and it has increased slightly and the mpg is 25 at the moment (by the trip computer) 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Fri Feb 26 2010 11:36am |
C10KO Member Since: 04 Jan 2009 Location: . . . searching . . . Posts: 1136 |
Mate, there is nothing to worry about. My mum uses her FFRR TDV8 (previously TD6) to drive to office (about 2 miles). In the last 8 years she hadn't had any problems at all. Only advise would be to stay gentle with the throttle whilst the engine is cold. Though if I were you I would give the engine occasional blasts when warmed up |
Fri Feb 26 2010 11:48am |
Jonny Fresh Member Since: 04 Feb 2008 Location: Manchester Posts: 3586 |
My daily commute is 2 miles each way and I am never gentle on the throttle or worry about the engine being cold.
Fri Feb 26 2010 12:22pm |
Lawrence22 Member Since: 04 Feb 2010 Location: Belfast Posts: 57 |
I used to drive a Mazda RX8. When it was cold the engine was limited to 6000rpm, when it heated up you could take it further 9000+. I am surprised that land rover and other manufacturers haven't fitted similar systems to prevent damage to cold engines. Said RRS is now on order. |
Fri Feb 26 2010 12:56pm |
The car will be under warranty (will extend at 3 years) so is there anything in it about not making short trips? |
Fri Feb 26 2010 4:41pm |
Alicatt Member Since: 11 Jun 2007 Location: Eating in Eksel or Ice cold in Alex Posts: 1435 |
the battery is the one weak spot I have on mine and if I done a lot of short trips like that in this cold weather the battery would be dead by the 5th run Sons of dogs come hither and get flesh
Fri Feb 26 2010 5:50pm |
Have you thought of fitting a 2nd battery? 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Fri Feb 26 2010 6:55pm |
No And Victor hasn't mentioned it a 1000 times over the last week or so... Sons of dogs come hither and get flesh Clan Cameron |
Fri Feb 26 2010 7:22pm |
4wheeldriver Member Since: 13 May 2009 Location: Aberdeen Posts: 955 |
Go Victor!! Go Victor!! Go Victor!! Current, M135i in Estoril Blue with more extras than the cast of Ben Hur.
Fri Feb 26 2010 9:45pm |
MAW Member Since: 06 May 2006 Location: Lincs Posts: 3104 |
Who would know you usage / driving style |
Fri Feb 26 2010 10:11pm |
