![]() | Home > Technical > DRIVERS WING MIRROR |
SALMON FISHER Member Since: 13 Jan 2007 Location: ,GLASGOW Posts: 115 ![]() ![]() ![]() |
When i'm on the motorway and its raining, the rain for some reason streams across my drivers window from the front screen and makes it impossible to see out of my wing mirror,i have noticed this does'nt happen on the passenger side.
I've heard of that before.... and I'm sure there was a solution. I've looked but can't find it right now. Might be worth a search in the morning... |
Steuart64 Member Since: 24 Dec 2009 Location: Aberdeen Posts: 539 ![]() ![]() ![]() |
Take a day off? |
KevinJM Member Since: 16 Dec 2005 Location: Belgrade this week Posts: 120 ![]() ![]() ![]() |
if you had a left-hand drive you would have water streaming across the driver window also - but on left hand side. The wipers sweep it all away and it seems there is no channel on the pillar to let it run down instead of spilling back onto the side window - at higher speeds it's really irritating, especially with road salt, grime and grit being splashed up from traffic RRS TDV6 (gone)
Bradders Member Since: 08 Oct 2009 Location: Leeds Posts: 2515 ![]() ![]() |
Try Rain X or something similar on the glass - helps the rain to bead and run off. Might need reapplying every month or so but this should help to keep the window clear. FF 4.4 V8 Soooo looking forward to this bad boy
