Home > Technical > Start up - idle/running issues |
Sounds like you might have a problem with your glow plugs. It could also be your EGR valves sticking open or crap in your fuel filter. 2005 Zambezi TDV6 - Gone but not forgotten
Thu Feb 18 2010 9:12pm |
accyis Member Since: 05 Feb 2010 Location: Lancashire Posts: 109 |
Hi VA, thanks for your quick reply. My limited experience with car issues pointed me towards the plugs as there doesn't appear to be an issue once the engine has warmed slightly.
Thu Feb 18 2010 9:35pm |
RRSSTEVE Member Since: 17 Jan 2010 Location: POOLE DORSET Posts: 15 |
hi would not recomend diy job as it requires high pressure fuel pump removal, anyway most cold start issues are caused by poor fuel quality. use a good non supermarket fuel and after the sevice you may find problem has cleared. egr faults are generally acompanied by smoke from exhaust and loss of power. if worried still suggest trip to dealer for afault code read. hope this helps, steve. |
Fri Feb 19 2010 10:01pm |
Thanks Steve, I have noticed smoke on start up. The vehicle booked in with dealer next week. I'll post the outcome. |
Fri Feb 19 2010 10:35pm |
Big D Member Since: 16 Jan 2009 Location: Glasgow Posts: 12 |
Hi accyis, any update on this as I am encountering similar issue, no response from Accelorator when the car is cold. After about 2 mins, all runs as normal?? |
Sat Mar 27 2010 3:15pm |
