Steuart64
![](templates/vbnew/images/spacer.gif)
Shouldnt name the dealer - unfair!!! | |
Put the RRS in for warranty/Recall work yesterday.
Included was the following with dealers response:
1. Seat belt wearing B Pillar. Resp. Normal wear and tear. I challenged stating the same issue on FL2s being repaired as a warranty item. Still wear and tear Sir. OK If you have wear on one material you have it on the other are my seat belts safe. Normal wear and tear Sir. I gave up for now.
2. Power delivery slow resulting in sudden take off effect. Resp. Normal operation for an automatic Sir. I also challenged stating that Id agree in an old DAF belt driven transmission but not in an executive class car. My Audi A4 auto was smoother. Resp. Well this is a heavier car Sir. I asked if that was an admission that the transmission/power plant were inadequate for the body the reply was , "I am advised that is normal".
3. Cabin temperature not constant. Resp. User fault Sir you had it in Auto. I replied yes and that mean I expect the climate control to keep a constant temp at the figure I set. Yes Sir but you will get hot and cold from the vents. I agreed as that is indeed how you control a constant temp but it shouldnt mean the cabin takes a constant dip to an uncomfortable temp. the response was its operating normally. I then mentioned the Tech Bullitin on the "thermal Sock " over the sensor and... "Oh a tech bulletin, we will look agian.
Do they not realise people talk and exchange experiences in this day and age of email/forums etc.?
I asked why my car lay on the forecourt for 2.5 hours before they started work and was told - normal practise!!!! I am glad it is warranty and I wasnt paying for those "labour hours"!!!
I work in a customer service company and if I was as unhelpfull I'd be run off!!! Now - MY11 RRS Autobiography TDV6, Orkney gray, tints, steps, daylight running lamps and allllll the toys!!!
Ex- RRS HSE TDV6 07 Java Black, bi xenon, corner lights, side steps, tints, cool box, smoke side repeats, chrome "sport" boot sill
Ex - Audi A4 Cab 3.0TDi Quattro
Ex - Freelander2 SE TD4
Ex - CRV Auto
Wed Feb 17 2010 3:44pm |
Steuart64
Maybe I need to go where proper customer service lives! After all, I do love driving the car!!!
I shall see what is reported tomorrow and maybe go see x x - Ooooops a clue!! Now - MY11 RRS Autobiography TDV6, Orkney gray, tints, steps, daylight running lamps and allllll the toys!!!
Ex - CRV Auto
Wed Feb 17 2010 4:31pm |
Steuart64
Had a call yesterday and the B pillar fitting is on order!! Only told the rest of the car was ready but didnt go into specifics as I was then told they had dented the car and it was away to a body shop for repair.
At least they told me and are taking care of it.
Oh well a few more days in the sprity FL2!!! Now - MY11 RRS Autobiography TDV6, Orkney gray, tints, steps, daylight running lamps and allllll the toys!!!
Ex - CRV Auto
Fri Feb 19 2010 7:53am |
