Home > Technical > Wheel Alignment
yogibear
United Kingdom 2007 Range Rover Sport TDV6 SE Java Black
Wheel Alignment
My car is going in for a full tracking check at LR tomorrow and I know that there is geometry set up that they use to do this, tracking, toe in and out etc. Is the set up different, for different wheel sizes,
I.e. if I change from 18" to 20" and vice versa.
Thanks
Post #256026 Wed Feb 17 2010 3:08pm
Bob.
Hi Yogibear
I believe there is only one set of alignment settings regardless of whether it's 18,19 or 20in wheels. If you go above 20in you are on your own as far as LR are concerned.
If the dealer carries out a full 4 wheel alignment and the steering wheel has been repositioned on the column make sure that they have recalibrated the steering angle sensor as the last operation, otherwise you may well be treated to a new set of warning lights in the not to distant future. This has happened to me twice.
Post #256092 Wed Feb 17 2010 9:48pm
