![]() | Home > General > tailgate gas strut question |
umbertob Member Since: 22 Sep 2005 Location: Pasadena, CA Posts: 944 ![]() ![]() ![]() |
Mine were replaced twice under warranty and one more time after expiration (on my dime), to my dealer's credit during the warranty period they didn't attempt to explain or justify anything and just put new struts in. Cold weather seems to exacerbate the problem, BTW. Stiff hinges, huh? That's a pretty crafty explanation, although defective hinges should be covered by warranty as well, IMHO. |
accyis Member Since: 05 Feb 2010 Location: Lancashire Posts: 109 ![]() ![]() ![]() |
Hiya, thanks for your quick reply. I will be chasing the matter up with regard to the gas struts. It was five mins to closing time when i picked up my car and felt like i had wasted my time. I'm starting to feel my custom has become second class following the initial purchase six months ago. Thanks again. |
zoo Member Since: 05 Sep 2009 Location: London Posts: 95 ![]() ![]() |
thanks for this post accyis - I had no idea that the tailgate should go all the way up on it's own.
Bradders Member Since: 08 Oct 2009 Location: Leeds Posts: 2515 ![]() ![]() |
I cant tell you how many times I took our FL2 back to the dealers to be told by the service receptionist "thats not a warranty job sir" only for the guy she sends out to check on the car, to agree straight away that it is! FF 4.4 V8 Soooo looking forward to this bad boy
Yes, it must. If yours dosen't then the struts need to be replaced or you can try a strong dose of Viagra! ![]() 4.2SC Chawton White, Stormers Tasmod's Sills, Wind Deflectors, LR Sills Clear Side Repeaters, Towbar Larini Sports Exhaust, K&N Air Filter ______________________________ WINNER - 2008 'Tech-Head Of The Year' Award WINNER - 2009 Outstanding Contribution WINNER - 2009 'Tech-Head Of The Year' Award |
mrloudly Member Since: 30 Dec 2009 Location: Naseby Northants Posts: 48 ![]() |
When it gets cold the gas reduces in volume, the oil contained within the gas springs also increases in viscosity
Hi. Brilliant response, thanks. Whilst i'm dealing with this i've always wondered if the the tailgate should be soft close. Mine is an 05 model and i recently test drove a 2010 model which had this. It got me thinking maybe it's something i should be getting repaired under warranty? Or will i look foolish if the 05 model was never designed to do this? All info welcome. Thanks. |
Soft close is produced by adding more oil to the cylinders. As you extend the unit the internal piston metering holes have to pass through oil rather than gas thus slowing the action. More oil will increase the force at full deflection as it reduces the initial free volume of gas. It's all about gas laws and I don't mean CORGI |
Isn't the soft close due to the power striker? Malaysia Boleh!
purple people eater Member Since: 10 Dec 2009 Location: Miles beyond midlife crisis Posts: 990 ![]() ![]() |
cracked my head on the tailgate today because it opened slowly and I beat it to position "A" |
Also as it's a 2005 car check that the bolts holding the struts have not come loose or sheared, there was a problem and TSB for very early RRS and D3 where the struts were able to come loose. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Accyis - thanks again for posting this thread. The dealer has confirmed that my struts are being replaced under the extended warranty. I would never have even been aware that the tailgate wasn't a "push-up exercise" had I not seen your post.
rrsboy Member Since: 06 Jan 2009 Location: UK Posts: 1391 ![]() ![]() |
can someone clarify exactly how it opens 'by itself'? is this you pushing the lock button in, then with no further action it lifting itself to the full open position? or do you have to guide it to 'horizontal' with your hand, then it will take it to full open?
Lookers Park Royal Member Since: 15 Nov 2007 Location: London Posts: 2303 ![]() |
RRSBoy,
