Home > General > 2010 model, steering wheel auto position = going up with
Jimmy_75000
2010 model, steering wheel auto position = going up with the driver door open but seat not moving....Isn't it suppose to move backward as well??? Range Rover Vogue ‘17 TDV6
Gone: Range Rover Vogue '11 4.4TDV8, Range Rover Sport ‘59, Range Rover Sport ‘56
Post #254267 Mon Feb 08 2010 7:19am
purple people eater
Re: 2010 model, steering whell auto position = going up with
Jimmy_75000 wrote:
steering whell
we do need that spell checker after all Whistle purple people eater
There are no good days, just some days that are not as bad as others!
Gone RR 4.0 P38 Autobiography MY99 Red ( Evil or Very Mad money pit)
Gone Big Cry RRS MY06 2.7TDV6 HSE Rimini Red
Gone RRS MY10 3.0TDV6 HSE Bali Blue with lots of bits (never grew to love it)
Here Now - 3.6 TDV8 FFRR OVERFINCH Stornoway Grey - loving it x
My work car Ford Mondeo 2.0 TDci Zetec auto Estate in Silver
Post #254275 Mon Feb 08 2010 8:29am
ASH555
England 2010 Range Rover Sport 3.0 TDV6 HSE Zermatt Silver
Can't remember mine moving at all MY10 3.0 TDV6 HSE, Zermatt Silver, 20" Diamond Turned Alloys, Factory Privacy Glass, Premium Leather, Contrast Stiching, Side Steps, Etc
Gone 2006 '56' 2.7 TDV6 HSE, Zermatt Silver, 20", Side Steps, Brembos, Dynamic Pack, Etc
VW Transporter, 19" Rims, T32 170 BHP, Lowered
Post #254279 Mon Feb 08 2010 8:53am
Landlord
United Kingdom 2010 Range Rover Sport 3.0 TDV6 HSE Alaska White
IIRC depends on the original setting. If your a big Censored and seat already back and low it wont move. However if you have the seat forward it moves back to let you out. Didnt realise this until I had adjusted the seat and wheel into a different position.
Now when ignition turned off and drivers door opened seat and wheel move slightly Thumbs Up MY10 TDV6 HSE, Alaska White, Ebony with Contrast, Park Heat, Paddle Shift, Privacy, Heated Steering Wheel, Extended & Premium Leather,
MY07 TDV6 HSE, Zermatt Silver, Gone
1964 Austin Healey 3000
2007 LR Defender
2011 VW Tiguan R Line
Post #254280 Mon Feb 08 2010 8:57am
ASH555
So shouldn't the setting be call 'short arse' Laughing MY10 3.0 TDV6 HSE, Zermatt Silver, 20" Diamond Turned Alloys, Factory Privacy Glass, Premium Leather, Contrast Stiching, Side Steps, Etc
Post #254282 Mon Feb 08 2010 8:59am
Landlord
Did cross my mind !
However I have raised the seat by about 1cm and the steering wheel down by about 1cm from standard and it still moves slightly as to make no real difference other than to impress the passengers when getting out Smile MY10 TDV6 HSE, Alaska White, Ebony with Contrast, Park Heat, Paddle Shift, Privacy, Heated Steering Wheel, Extended & Premium Leather,
2007 LR Defender
Post #254284 Mon Feb 08 2010 9:04am
Jimmy_75000
Embarassed sorry about the mistakes.... Sheep ..... typed on my iPhone ....!
OK, so will give it a try with the seat all the way forward! Range Rover Vogue ‘17 TDV6
Post #254288 Mon Feb 08 2010 9:32am
umbertob
United States 2006 Range Rover Sport 4.4 V8 HSE Chawton White
Guess what, it may be yet another electronic glitch with the 2010s, someone flipped the wrong switch at the factory. Here is the SSM on the GTR web site, 0.2 hrs to fix excluding dildo, haha:
Quote:
Models
LS - Range Rover Sport
LA - Discovery 4
Title 10my entry/exit feature does not operate correctly
Last Modified 07-OCT-2009 17:43
Category Electrical
Symptom 203000 Basic Electrical
Content
Issue
If the entry/ exit feature has been enabled by setting the steering column switch to the auto position when entering the vehicle and closing the door, with ignition on, the customer will note that the steering column has moved to the preset position but the seat has not and when exiting the vehicle the column will move upwards but the seat does not move down.
Cause
The seat feature has been disabled in error.
Action
This issue affects 10my Discovery 4/LR4 and Range Rover Sport vehicles between the following vin numbers
Range Rover Sport AA513326 to AA518210
Discovery 4/LR4 AA215623 to AA221673
The feature can be enable through IDS from DVD118.5 Patch 15
Set-up and configuration \\ Seats \\ Seat entry/exit enable
The SRO number is:
789105 Seat enable/disable - configuration 0.2Hr Excluding DIDO
Post #254402 Mon Feb 08 2010 6:04pm
