Home > Technical > Passenger Doors Jammed Shut!!! HELP.....
mrtwo
United Kingdom 2006 Range Rover Sport 3.0 TDV6 HSE Santorini Black
Hi All,
I have a 2006 Sport and and bit of a problem.
The Front and Rear passenger doors have locked them self shut, I cant open them from the inside or our side! i have treid the key in the front door but no good, i have tried locking and unlocking with the remote but both doors are locked and can't get in at all??
Any ideas out there?
Many Thanks
Craig...
Post #253825 Fri Feb 05 2010 9:07am
Landlord
United Kingdom 2010 Range Rover Sport 3.0 TDV6 HSE Alaska White
Rear lock acutators are know to give up. Sounds suspicious that both have gone at the same time.
Have you accidentaly disabled the locks using the child locks ? MY10 TDV6 HSE, Alaska White, Ebony with Contrast, Park Heat, Paddle Shift, Privacy, Heated Steering Wheel, Extended & Premium Leather,
MY07 TDV6 HSE, Zermatt Silver, Gone
1964 Austin Healey 3000
2007 LR Defender
2011 VW Tiguan R Line
Post #253830 Fri Feb 05 2010 9:17am
Could be a sign that the battery is dead or on its last legs...
The mechanical release is detailed on here somewhere - have looked but cannot seem to find it Confused
Post #253832 Fri Feb 05 2010 9:19am
MAW
Which doors are locked - not clear, F&R passenger, so rear two and front passenger? You can get in OK?
Does the tailgate work ? Fuel flap open?
Double tap the open on the key fob - still the same?
Post #253971 Fri Feb 05 2010 6:09pm
accyis
United Kingdom 2006 Range Rover Sport TDV6 HSE Zermatt Silver
Hi. I have a 05 model and it has just been in for a warrenty repair due to the rear passenger door not operating with the remote. Before i took it in i managed to open the door by climbing inside and holding the lever in the open position then operating the remote key. You can hear the actuator move and the door unlocked. Without the assistance it appeared that the actuator didn't have the strength to create this operation on it's own. I was told the latch was replaced. Having only owned the car for two months i was a bit dissappointed!
Post #254016 Fri Feb 05 2010 11:11pm
robert997
We've had this 3 times in the last year on our 2006 car, it seems to arive without provocation. Agree with accyis that if you open the handle on the inside whilst pressing the fob/dash unlock button you can open the door, but this doesn't cure it. Have had 3 door lock replacements under warranty.
Colleague with D3 has also suffered, must be 'known' fault.
Post #255451 Sun Feb 14 2010 2:37pm
