Home > Technical > Suspension fault |
PJPR01 Member Since: 12 Mar 2006 Location: Houston, Texas Posts: 355 |
99% likely that you need a new battery...that tends to throw these types of faults. PJPR
Thu Feb 04 2010 5:33am |
MAW Member Since: 06 May 2006 Location: Lincs Posts: 3104 |
If not that it could be a bad sensor - they are currently on recall and if you search on here and D3 you'll find posts on it - I had it around 3 weeks ago. LRA fitted a new sensor. |
Thu Feb 04 2010 8:03am |
C10KO Member Since: 04 Jan 2009 Location: . . . searching . . . Posts: 1136 |
It can also be a water leak that has damaged your ECU - I have had a similar problem on a 2005 TDV6 |
Thu Feb 04 2010 9:34am |
Landlord Member Since: 26 Sep 2006 Location: Hampshire Posts: 607 |
Had the same thing 3 times over 3 years on my last Sport. Either cleared itself over night or dealer reset fault code. Hopefully its nothing much to worry about MY10 TDV6 HSE, Alaska White, Ebony with Contrast, Park Heat, Paddle Shift, Privacy, Heated Steering Wheel, Extended & Premium Leather,
Thu Feb 04 2010 11:40am |
