![]() | Home > Technical > recall for the high pressure fuel pump |
Does your HSE have the optional DR system fitted - it could be they want to fit the new style suspension bushes 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
muffd Member Since: 20 Jun 2007 Location: Glasgow, Scotland OR Cumbre del Sol, Spain Posts: 325 ![]() ![]() ![]() |
Hi Tim
Does your car have the front end rattle when you go over rough roads or bumps. DR is the hydraulic anti-roll bar system that is standard on TDv8 and S/C's but was optional on the 2.7's. IIRC you also got 20" 10 spoke alloys (supercharged style) and adaptive headlights in the package too 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Hi Tim
Probably they mean the Recall P008 issued last September?
Steuart64 Member Since: 24 Dec 2009 Location: Aberdeen Posts: 539 ![]() ![]() ![]() |
On my LR printout I have these as fitted.
I do have adaptive xenon headlights that follow the steering - so she does have DR. The stealers just called me and they have now admitted there is indeed a knock. Despite 3 visits in the past to 2 separate dealers, they have always maintained this is a characteristic of the car......
Steuart you don't have to worry - sounds like you don't have the trick suspension - All RRS's have the air suspension, and ACE. If you don't have adaptive Bi-Xenons you don't have the DR. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Cheers Tim
Just check Parker's isn't referring to the Dynamic Pack, which isn't the same as Dynamic Response 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
They quote:
Just checked my 2007MY (September 2006) price list - Dynamic Pack was an option only on S and SE, and consisted of(and this is were it gets confusing!) Dynamic Response, 20" 10 spoke wheels, Brembo front brakes, and Bi-Xenon Adaptive headlights. and was a very pricey extra at £5050 on an S and £3250 on an SE. Dynamic Response as you say became standard on HSE, pre 2007MY the DP was also an option on HSE's. So potentially there are a huge number of cars dating from October 2006 that could have the rattly front end problem.................. far more HSE's have been built than S or SE's too. No wonder LR isn't that keen that there is a problem in the system! 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Wow Tim, Do you keep a library of brochures?
Bob. Member Since: 02 Feb 2009 Location: SWest Posts: 275 ![]() ![]() |
Hi Muff Yes mine has a corrosion spider as well and had not been used until last November. I will be interested to hear what response you get from LR. |
