![]() | Home > Technical > Which wheel nut? |
tornado34 Member Since: 06 Dec 2009 Location: London Posts: 242 ![]() ![]() |
I need to know the correct spec of wheel nut I should use on my late 2005 RRS. I am fitting MY2010 20" alloys and need to know the correct nut to use. (yes, I have steering damper model, so should take 20" ok - phew!!).
MAW Member Since: 06 May 2006 Location: Lincs Posts: 3104 ![]() ![]() ![]() |
Why not drop them a line with the question on the email addy on the advert or have you done that? |
C10KO Member Since: 04 Jan 2009 Location: . . . searching . . . Posts: 1136 ![]() ![]() ![]() |
MAW, I am surprised that you can not source a set of wheel nuts. Or are you not collecting those yet? |
Bob. Member Since: 02 Feb 2009 Location: SWest Posts: 275 ![]() ![]() |
Don't know what the change was but from 05MY up to 08MY at VIN 8A130279, non locking nuts are LR part no RRD500290 but for cars after that they fitted RRD500590. That includes 10MY. Clearly there is a difference between 05MY and 10MY nuts but whether it's just cosmetic or something more important I don't know.
LR are not so helpful on this. They said you shouldn't fit MY2010 20" alloys to pre MY2010 cars. Therefore they would not suggest a nut to use. The reason appears to be linked to this random fitment of the steer damper (some cars have it so don't depending on which they had available at the time of manufacture - not recorded against the VIN!).
lespes Member Since: 16 Jun 2008 Location: Channel Islands Posts: 1052 ![]() ![]() ![]() |
The man who would know is Nick parts manager at Yeovil Landrover.
cheers lespes, have PM'd him. |
OK, back to you RRS guys.....I PM'd Nick on Disco3 but no reply!
Phone your dealer or another, lie about the scenario and tell them you want a set of spares |
Maybe I could use the current ones, but it all became very confusing when I first asked the question way back when. First I needed spacers or shims, then not. Then I could use my existing wheel nuts if they were 'bright ones' not 'dull' ones - or the other way around - now I have no idea.
No problem with putting my 19" wheels on with the wheelnuts from the 20's......................... in 2 winters no 19" wheels have fallen off and there hasn't been any damage to the wheels BUT they are both pre-2010MY wheel designs 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
