![]() | Home > Maintenance & Modifications > Changing the SATNAV DVD disc |
Steuart64 Member Since: 24 Dec 2009 Location: Aberdeen Posts: 539 ![]() ![]() ![]() |
I have read the manual and the process seemed simple until I accessed the underseat area.
You'll be fine, Steuart - you can't damage anything and as Skywalker says you need to move the seat into the right position so you can access it. It's still not the easiest place to access, but once you get the seat moved it'll be easier for you to see what needs to happen |
Cheers fellas
Jimmy_75000 Member Since: 06 Oct 2006 Location: London, UK Posts: 1146 ![]() ![]() ![]() |
![]() ![]() Gone: Range Rover Vogue '11 4.4TDV8, Range Rover Sport ‘59, Range Rover Sport ‘56 |
4wheeldriver Member Since: 13 May 2009 Location: Aberdeen Posts: 955 ![]() ![]() ![]() |
If youve any problems with it give me a shout and I'll pop over. I did mine after a bit of sweary language for a kick off.............. |
Many thanks to all
No worries. Just drop me a pm with a number or a where and when! Current, M135i in Estoril Blue with more extras than the cast of Ben Hur.
