Home > Technical > Will Not Start in Cold Weather
Andybon0
England 2006 Range Rover Sport TDV6 S Santorini Black
Have an intermittent fault with TDv6 diesel starting in cold weather which has flattened the battery, jump started it from my wife�s Ford Galaxy when weather warmed up to about 4degrees and started ok.
Next morning over night frost and wouldn�t start again, call RAC out they started it with jumping and some spray (don�t know if some sort of quick start stuff?) RAC man suggested problem was glow plugs??
Took to local LR specialist who said battery was low and not glow plug as no fault on computer, they recharged battery started fine and thought problem solved
Next morning wouldn�t start so back to LR specialist, now saying primary fuel pump not pumping at high enough pressure but not fault code re low fuel pressure on RRS�s he is waiting for a gauge to check pressure so still waiting answer , anyone any ideas???? Sad
Post #249260 Tue Jan 12 2010 10:53am
2nd Rower
Australia 2008 Range Rover Sport TDV6 HSE Chawton White
Maybe you need a new Battery? Question
Post #249264 Tue Jan 12 2010 11:06am
Andybon0
Local LR specialist swapped battery in workshop and still same problem a complete mystery?
Post #249270 Tue Jan 12 2010 11:27am
Trace back to starter and check there - could also be fuel filter (maybe pump).
A few instances of cold starting issues recorded here - search for "+cold +start" Very Happy
Post #249272 Tue Jan 12 2010 11:37am
Gary
This may be a stupid question but are you allowing the glow plug light on the dash to go out before trying to start, as the engine will not fire up untill the plugs are ready and the yellow plug light out will tell you?
Post #249280 Tue Jan 12 2010 12:19pm
Andybon0
Yer tried that one Gary waited for glow lights to go out and computer system to sound a bing noise
Post #249283 Tue Jan 12 2010 12:42pm
Gary
Oh dear, back to the drawing board then!
Your local specialist is that the one off Progress Rd?
Post #249292 Tue Jan 12 2010 1:30pm
Andybon0
No Gary, just off Stock Road southend , went to progress road for last service, they changed the fuel filter but couldnt find any fault codes re starting
Post #249295 Tue Jan 12 2010 1:39pm
Andybon0
Latest from garage is that they believe the car has been mis-fuelled with some petrol in the diesel tank, having Confused checked with previous owner who put �1.76 of petrol in 40k miles ago.
Garage checking if to change one or both fuel pumps and or injectors sound very expensive, however runs but lumpy when idling
Confused
Post #249500 Wed Jan 13 2010 1:13pm
I hope you bought the car from a LR dealer. 2005 Zambezi TDV6 - Gone but not forgotten
Post #249502 Wed Jan 13 2010 1:20pm
Andybon0
Afraid not Big Cry
Post #249510 Wed Jan 13 2010 1:35pm
Oh dear! Sad 2005 Zambezi TDV6 - Gone but not forgotten
Post #249515 Wed Jan 13 2010 1:59pm
