![]() | Home > Technical > Light Protectors |
C10KO Member Since: 04 Jan 2009 Location: . . . searching . . . Posts: 1136 ![]() ![]() ![]() |
First, you need to remove the lights following the instructions in the owners manual. Then it is straight forward, you will see what you need to do. Though, remember that removal of the guards will leave holes on the grill |
NasMan Member Since: 06 Jan 2010 Location: West London Posts: 102 ![]() ![]() ![]() |
Thanks - Yes I noticed they are screwed into the grill... Will get LR to remove on service, and change grill...
Josh Member Since: 24 Dec 2005 Location: Here, there and everywhere Posts: 2054 ![]() ![]() |
So why don't you two meet up and just swap the bits. Would be cheaper than getting a dealer involved |
Josh, that is actually not a bad ideal at all |
