![]() | Home > General > How to drive in snow and ice for the uninitiated ? |
crowej Member Since: 21 Apr 2008 Location: Dublin Posts: 289 ![]() ![]() ![]() |
Hi Guys,
wokkaman Member Since: 08 Nov 2006 Location: GU34 Posts: 761 ![]() ![]() ![]() |
Depends how severe and how big the hills? But a good guide; DSC - OFF - thats the LR way according to the official off road DVD for driving in Snow GGS - ON - best setting ever, troll the forums to see its praise Low Range - ON for the big hills etc HDC - ON I have used it the past few days and can only just find the brake pedal ![]() Off Road Height - SET - miss all the chuck of ice or deep snow Just keep in mind Low range and Off road height means keep under 30mph GONE** RRS 3.0SC Silver fully loaded ![]() BMW R1200GSA Rallye GONE** Fiesta ST2 - Mrs Wokka's - AMG35 now GONE**BMW K1600GTLE Matt Blue GONE**Disco 4 2014 Firenze Red GONE**Evoque SD4 Dynamic Coupe GONE**RRS 5.0 SC GONE**RRS HSE TDV8 GONE**RRS HSE TDV8 (The Crap one) GONE**FL Facelift GONE**FL 1 GONE**D1 GONE**BMW R1200GS Adventure GONE: Kawasaki ZX10R GONE: Focus ST2 ** Chinook CH47 - 2 x T55 engines 3,750 hp each!! 183mph, 2xM134 Miniguns, 1xM60 |
purple people eater Member Since: 10 Dec 2009 Location: Miles beyond midlife crisis Posts: 990 ![]() ![]() |
cant go wrong following wokka's advice. GGS marvelous tool, but everything slow smooth and easy, just like in bed |
As Wokka says - but don't touch the brake pedal if you have the HDC engaged, that will disengage the HDC, just let the car do the work! Also if you are in low ratio use 2nd and 3rd not 1st gear for pulling away. Only use first in manual shift mode for going downhill and use the engine braking to keep the speed down. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
ViewWise Member Since: 13 Mar 2008 Location: London Posts: 704 ![]() ![]() ![]() |
yea i think the biggest part about snow driving is using command shift to down shift coming up to junctions to reduce the speed. Definitely avoid any sudden/slight hard braking. WINNER - 2008 Best All New Photograph
One thing you will also notice in GGS setting even in high ratio box is how much "damping" it applies to the accelerator pedal, almost to the extent that you think there is something wrong with the car! If you cna get to speeds above 20mph then I would recommend disabling the HDC until you have to drive more slowly, only because it can eat up brake pads and discs when it activates a lot and if you can get to that sort of speed or more then the roads must clear anyway. There also doesn't appear to be an upper speed limiting gong when you have GGS engaged in high box with normal suspension height. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Alicatt Member Since: 11 Jun 2007 Location: Eating in Eksel or Ice cold in Alex Posts: 1435 ![]() ![]() ![]() |
Also take care when you switch back to normal from GGS as your foot has to re-learn how hard to press the throttle |
C10KO Member Since: 04 Jan 2009 Location: . . . searching . . . Posts: 1136 ![]() ![]() ![]() |
Have to hand it LR.........that GGS setting is unbelievable, you can feel the grip as soon as it goes on.........known in the family as "Tiger mode" |
WW, no need to disable the DSC on roads that have been already driven, you only disable it to get out of the sticky bits when you may want to start using the front wheels to get extra grip by turning the steering wheel quickly form side to side, DSC thinks you are going to crash the car and cuts the power! 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Josh Member Since: 24 Dec 2005 Location: Here, there and everywhere Posts: 2054 ![]() ![]() |
I drove mine in very deep virgin snow 1 1/2 feet deep today using all the tips on here at varying times. Did a few miles like that. Spot on even with Contis |
Not had that with the snow yet but had it with mud, thought I had lost the wheel weights and I had even used a pressure washer to get the mud off but there was some still on the inside of the wheels, had to take them off to get them clean and then they were ok.
Smarticus Member Since: 26 May 2005 Location: Northumberland Posts: 939 ![]() ![]() ![]() |
Defo leave DSC on unless you are actually stuck. The secret is to keep the car straight and the DSC can help you do that. A little bit out of shape in snow or on ice can quickly turn into a lot of out of shape. If the laws of physics take over from the clever electronics you can feel like you are in an out of control huge chunk of metal very quickly. And once you are in the ditch it can be a tractor job to get you out.
my suitable "spares" bottle Glenfiddich, bag of doritos, ipod and hybrid TV, sitting in rush hour traffic for 3 hrs in Sheffield everytime it snows, priceless purple people eater
