Home > General > Land Rover Assist Already |
JC1 Member Since: 24 Oct 2009 Location: Berkshire Posts: 939 |
Less than four weeks old and i will have to give them a call in the morning |
Wed Dec 30 2009 11:16pm |
npinks Site Moderator Member Since: 26 Nov 2007 Location: Watching Posts: 6716 |
What's happened? |
Wed Dec 30 2009 11:20pm |
Says low battery and will not start, could put jump leads on it but there is clearly more to it than that, only used it yesterday, nothing left ON, lots of warning lights when u try to start gearbox etc and the clock goes mad. I do hope this is a blip and not a sign of things to come. |
Wed Dec 30 2009 11:34pm |
ASH555 Member Since: 02 Dec 2006 Location: East Yorkshire Posts: 750 |
I think somebody else had a problem with the battery on a new RRS, hopefully a quick exchange will sort it MY10 3.0 TDV6 HSE, Zermatt Silver, 20" Diamond Turned Alloys, Factory Privacy Glass, Premium Leather, Contrast Stiching, Side Steps, Etc
Thu Dec 31 2009 10:42am |
RichardM Member Since: 24 Sep 2009 Location: Herts Posts: 745 |
There are a few posts on the Discovery 4 forums about battery issues with new cars. It seems to happen if the car was left standing for a long time before delivery. The solution seems to be to fully trickle charge the battery using a charger. WINNER - 2009 ‘Just Doing What It’s Designed To Do’ Award
Thu Dec 31 2009 2:09pm |
Gazzer Member Since: 21 Oct 2005 Location: Salisbury Plain Posts: 318 |
My 2010MY sport has had 2 battery issues. First was low voltage warning on start up, thought it strabge as the car had been on some long runs. Then I went abroad and the missus said car wouldn't start. LR assist called and found no reason for the flat battery. All charged up and not had an issue since. My car was built on the 14th Sept and delivered the following week to dealer, so hadn't been left long. I think it was because I hadn't closed the glove box properly. It doesn't close very well on my car and needs to been slammed shut. Think the internal light drained the battery over a couple of days. 2010MY Land Rover Freelander 2 HSE
Thu Dec 31 2009 2:48pm |
MAW Member Since: 06 May 2006 Location: Lincs Posts: 3104 |
I think all power drain sources are killed off shortly after key out. Even if you turn the radio on w/o the keys in it powers off after 20 mins or so - If all is working correctly nothing, (like the glove box light) can drain the battery on any RRS to date ( you cannot charge a phone or even keep a cool box cool with the key out) |
Thu Dec 31 2009 6:13pm |
