Home > Maintenance & Modifications > Egr and Butterfly valve removed.
iz6byo
2006 Range Rover Sport TDV6 HSE Buckingham Blue
hi all..
i have removed both this morning...
i have made 2 plate, hand made Smile, by a draw found on forum.
i fitted them on bottom part of the 2 tubes without removing them.
i have removed the black part from the butterfly valve.
now at 1000 to 1500 rpm the car it's smooth and a little more quick....
i recommend it to everybody...
bye Smile
happy new 2010
Post #247213 Wed Dec 30 2009 9:11pm
Tim in Scotland
have you also removed the Lambda probes? They are a potential source of problems if you are running without the EGR's in. I had to remove it from my TDi300 Defender's engine and it made an even bigger difference to the economy and smoothness 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #247223 Wed Dec 30 2009 11:04pm
iz6byo
hi Tim...
no only those 2 parts....
Post #247233 Thu Dec 31 2009 8:23am
Over on our sister site disco3.co.uk this has been a much talked about topic. Do a search over there to see their findings - if I remember correctly some have put EGR blanking plates in which seems to produce the best results. 2005 Zambezi TDV6 - Gone but not forgotten
Post #247234 Thu Dec 31 2009 8:44am
iz6byo
yes...
i can fell the difference al low Rpm...
very nice...
i have fitted 2 steel plates,hand made Smile
i saw the internal of tubes very dirty Crying or Very sad and i think it's not good for the engine...
now i know that takes clean air from filter....
happy new 2010
Post #247250 Thu Dec 31 2009 1:24pm
