Home > Technical > MY10 RRS-Park Heater Problem |
I wonder if the power drop when the DPH fires up is too much for the alarm system and it thinks that somebody is tampering with the main battery 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Wed Dec 30 2009 9:09pm |
Red1903 Member Since: 25 Jan 2009 Location: North East Scotland Posts: 156 |
Tim,
Fri Jan 01 2010 3:08pm |
ahhhhhh right so this question falls into the category of "1001 Great Range Rover Sport Mysteries", like the "can I lock the suspension down at speed?" question - it will do it by itself when it wants to! 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Fri Jan 01 2010 3:54pm |
ViewWise Member Since: 13 Mar 2008 Location: London Posts: 704 |
not sure how it works on the new keys, never checked.. Is there a dedicated park heat button or just a programmable one? In which case it might be programmed as a panic button instead of park heat? WINNER - 2008 Best All New Photograph
Fri Jan 01 2010 9:39pm |
Landlord Member Since: 26 Sep 2006 Location: Hampshire Posts: 607 |
Have used the Park Heat many times over the last 3 weeks. The alarm has gone off once so far, doesn't appear to be a regular problem.
Separate remote for park heat so not programmable MY10 TDV6 HSE, Alaska White, Ebony with Contrast, Park Heat, Paddle Shift, Privacy, Heated Steering Wheel, Extended & Premium Leather, MY07 TDV6 HSE, Zermatt Silver, Gone ----------------------------- 1964 Austin Healey 3000 2007 LR Defender 2011 VW Tiguan R Line |
Fri Jan 01 2010 10:28pm |
Alarm went off for second time tonight. -1 outside, alarm activated after about 10 minutes of heater being on. MY10 TDV6 HSE, Alaska White, Ebony with Contrast, Park Heat, Paddle Shift, Privacy, Heated Steering Wheel, Extended & Premium Leather,
Mon Jan 04 2010 8:46pm |
Exactly the same problem I have, 10 mins or so into the pre-heating cycle and the bloody alarm goes off and usually when I am in the shower |
Mon Jan 04 2010 9:58pm |
The problem will disappear once the weather improves MY10 TDV6 HSE, Alaska White, Ebony with Contrast, Park Heat, Paddle Shift, Privacy, Heated Steering Wheel, Extended & Premium Leather,
Mon Jan 04 2010 10:18pm |
Dont hold your breath regarding the weather improving. At present we have very heavy snow up in Grampian and it is due to slam into England Tuesday tea time. Silly amounts of snow are falling and have already decided not to even attempt to drive the 30 miles or so into work tomorrow. I wonder if my boss knows I drive a Range Rover |
Mon Jan 04 2010 10:23pm |
npinks Site Moderator Member Since: 26 Nov 2007 Location: Watching Posts: 6716 |
I'm not 100% on what the heater does apart from burn fuel to heat something up, but could it be that after 10 mins the car then switches the vents on in the car to circulate the hot air, tricking the internal alarm PIR sensors that somebody is in the car so it activates the alarm
Mon Jan 04 2010 10:36pm |
2nd Rower Member Since: 12 Nov 2007 Location: Upside Down Posts: 1382 |
For some reason made me think of this : http://www.youtube.com/watch?v=JF-KJ5-KNQk&feature=related |
Tue Jan 05 2010 10:17am |
wardpg Member Since: 27 Apr 2008 Location: preston Posts: 11 |
If you look at the Disco 4 site some people have been having the same problem and it seems to being caused by the direction of the air vents as they blow in hot air -altering the blowing direction seems to have cleared peoples problems |
Tue Jan 05 2010 2:42pm |
It's beginning to sound like a lot of buyers are ending up doing a lot of product testing that should have been done before the car was launched on the general public......................... now where I have I heard that before , DR suspension rattles, lack of FBH on early models, Gearbox problems on 2010MY, clumsy satnav/ human interface problems................................... I haven't heard of these problems with 2010MY FFRR so LR must have got them just about right, but then if I were paying that much for a new car I would expect it to be perfect 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Tue Jan 05 2010 4:48pm |
+1 RE the lack of testing! |
Tue Jan 05 2010 9:14pm |
