Home > Technical > Battery Issues |
lespes Member Since: 16 Jun 2008 Location: Channel Islands Posts: 1052 |
If confident Dealer has done good check and bearing in mind battery recently repleced would point to a short somewhere. The system has to go to sleep so when locked up usually takes about 5-10 mins to power down to sleep mode. If you have a short then it will not go into sleep mode and drain the battery very quick.
Thu Dec 17 2009 3:50pm |
