Home > Tips & Tricks > preserving your wiper blades/ motor
Tim in Scotland
Last few days here have been pretty cold (down to -10c, which is VERY COLD here on the sub-tropical West Coast of Scotland) - if you are in the habit of running all the time with the wipers in automatic mode, switch them to off when you leave the car at night and are expecting an overnight frost. Leaving them on auto will cause the wipers to immediately activate as soon as you turn the key to position 2 in the ignition, putting a strain on the wiper motor and can rip the blade off the wiper after a few times. The automatic on wiper sensor detects the screen is dirty when it has frost/ice on it and tries to clear it, causing above damage. Before you start the engine just 2secs to check can save the expense of new baldes half way through the winter - switch the wipers to off and start up then set the ventilation/heating to Prog and the sceens will clear in a minute and your wipers will be defrosted! But don't expect the washer jets to thaw out so fast! 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #245367 Mon Dec 14 2009 11:53am
good point there Tim
I do the same, and fully melt the ice before wiping as ice is another way to ruin a set of wipers when they run over it Thumbs Up
Post #245372 Mon Dec 14 2009 12:17pm
islider
United Kingdom 2006 Range Rover Sport TDV6 SE Java Black
Yep Good Call, Tim.
As they are Auto wipers you would think there would be a set temp overide say at 0c, to prevent this. Not on Manual mode though.
Washers are heated, so a little patience is a virtue.
Post #245374 Mon Dec 14 2009 12:44pm
Tim in Scotland
i, the nozzles are heated but not the lines carrying the fluid to them which freezes and stays frozen even though the nozzles have been thawed.................................... when will somebody think to heat the piping as well as the nozzles Question 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #245385 Mon Dec 14 2009 2:46pm
The doc
simply brilliant stuff Thumbs Up
Post #245391 Mon Dec 14 2009 3:01pm
Josh
I learn't that lesson last year Shocked Banging Head
Didn't damage the blades but it did loosen the nuts on the washers which was the last thing I needed cos it was blizzarding and I had an hours drive to work. Drove slowly to LR who kindly adjusted and retightened the nuts so that they worked foc. TDV6 - gone
TDV8 - gone
Post #245406 Mon Dec 14 2009 4:56pm
Tim in Scotland
Just looked at the 5ltr container of Halfrauds Extra strength washer fluid I bought in the summer and it has a dilution table on it:-
1 Measure fluid to 20 of water - normal weather
1 measure fluid to 4 of water - 0- -15c
1 Measure fluid to 1 of water -15 to -40c
Neat - below -40c
Well I can tell you that the 1-4 mix will still freeze at -5c to -11c I don't like using it neat as there is the possiblity of paintwork damage from the ethyl-glycol/ antifreeze in the stuff 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #245411 Mon Dec 14 2009 6:13pm
BKHK
Over here its sometimes a good idea to pull the wipers off the screen on hot summer days as they have been known to melt onto the screen in some cars...... Gone - 2008 Stornoway Grey RRS 2.7 TDV6
Post #245453 Mon Dec 14 2009 11:02pm
NasMan
Nice Tip Tim - Mate of mine just damaged his on a VW.. 4 Week waiting list, as is happening to lots of people... 57 RRS | TDV8 HSE | Java Black | Black Interior | Side Steps | 20" Alloys
Bought in Januray 2010. Colour Coded Car with Forum Members Help.
CURRENT - 2004 Mercedes SL350 | Silver - Best Car I have ever had Smile
GONE - Jaguar S-Type | Silver
Post #248231 Thu Jan 07 2010 2:01pm
purple people eater
A few (not that many) years ago when i was a teeneager starting my first job, a colleague had a Hillman Hunter, he had an add on heating system which i think involved running a small copper heating element along the screen washer pipes, and a think it also had a resevoire that was somehow heated by the engine. Dangerous in those days cos hot water on sub zero screen not a good idea, but with heated screens could work today purple people eater
There are no good days, just some days that are not as bad as others!
Gone RR 4.0 P38 Autobiography MY99 Red ( Evil or Very Mad money pit)
Gone Big Cry RRS MY06 2.7TDV6 HSE Rimini Red
Gone RRS MY10 3.0TDV6 HSE Bali Blue with lots of bits (never grew to love it)
Here Now - 3.6 TDV8 FFRR OVERFINCH Stornoway Grey - loving it x
My work car Ford Mondeo 2.0 TDci Zetec auto Estate in Silver
Post #248242 Thu Jan 07 2010 2:34pm
Tim in Scotland
Unless you have recently arrived from Iran PPE, you give your age away - Hillman Hunters are still built in Iran! 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #248279 Thu Jan 07 2010 6:31pm
Hillman Hunter - that makes you about 120! 2005 Zambezi TDV6 - Gone but not forgotten
Post #248280 Thu Jan 07 2010 6:33pm
purple people eater
I did have a banana yellow Hillman Hunter company car, then got a Hillman (sorry rebranded Chrysler, or was it Talbot) Avenger, does that give my age away? purple people eater
Post #248350 Thu Jan 07 2010 11:44pm
4wheeldriver
Scotland 2010 Range Rover Sport TDV8 Autobiography Stornoway Grey
I seem to have to reset the auto wipersin mine every time I get back into the car. Know for a fact they wont come on after the key has been out of the ignition cos I sat there with the rain building up trying to figure out what was wrong but as soon as I twisted the collar from auto back one click and then forward again the wipers sprang into life from there!!! That mean theyre knackered or something they changed in the 09 models maybe? Current, M135i in Estoril Blue with more extras than the cast of Ben Hur.
535d m-sport Platinum grey and a few extras.... Gone
X5 3.0 sd in Space Grey, 20's, Dynamic Pack, Memory Pack, Media Pack, Tow Pack, Rear DVD, Panoramic Sunroof, Steps, 7 Seat Pack, Reversing Camera with moving lines, programmable park heat, etc etc etc - Gone
Range Rover Sport Santorini, privacy, dvd, towpack GONE!!!
Post #248360 Fri Jan 08 2010 1:51am
Alicatt
Belgium 2008 Range Rover Sport TDV8 HSE Buckingham Blue
I had a Hunter GT way back then and a work mate had an Avenger Tiger that was quite a tasty car back then Smile
on topic... washers are still frozen here and have been for over a week now Sad Sons of dogs come hither and get flesh
Clan Cameron
Post #248388 Fri Jan 08 2010 10:17am
