Home > General > key fob reprograming 2006 rrs ywx000061
k11ngc
I have one key and want to get another key programed can I save a packet and buy one on ebay and then get a dealer to program or a speicalist locksmith? what would the cost be from a dealer and would they entertain a key fob from ebay? with the same serial No ywx000061 and is it easy to get the key blade cut ?
cheers guys if you can help? Stephen Hughes
Post #244239 Wed Dec 02 2009 9:26pm
MAW
If you search on here there are a few recent posts on this - IIRC around £125 dealer supplied - as for fleabay and risk ..... Confused
A dealer will want to make it worth his time £ wise
Speak to your supplying dealer for his view ?
Post #244248 Wed Dec 02 2009 10:48pm
2nd Rower
Australia 2008 Range Rover Sport TDV6 HSE Chawton White
I've recently had a new key via warranty - they aren't cheap so was thankful for the freebie.
I was told they had to be ordered against a cars specific VIN from the factory.
I am not sure though whether the VIN is programmed in at the factory, or if the VIN is just to ensure that the key part matches the cars ignition barrel and door lock, and that the dealer takes care of all of the electrnic pairing - which is the labour they carge you!
If your getting a completely blank one from Fleabay, then as well as the dealer electronic pairing, you're going to need someone who can cut the key for you to match your ignition barrel and door lock!
Post #244256 Thu Dec 03 2009 3:03am
umbertob
United States 2006 Range Rover Sport 4.4 V8 HSE Chawton White
Dealers can't program / reprogram key fobs that were not specifically issued for your VIN at the factory, they don't have the proper software. All they can do is enable or disable a key on the car it was originally programmed for. The EEPROM in the fob needs to be programmed at the Land Rover factory with your VIN and other vitals, checked against the data in the car's CPU every time you slide the key in the ignition. No match, no start. The blank blade may very well be cut to size by a locksmith, but all you'll be able to do with it is operating the emergency lock on the front door. The key will never start your car or remotely lock or unlock your doors. Don't waste your money on eBay, unfortunately you need to order any replacement or additional keys for the RRS through an (overpriced) dealer by showing them proof of ownership, then wait a few days for them to receive it from the factory, then bring them the car and all your remaining keys so they may sync / re-sync them all with your vehicle. If you leave any keys at home, once the dealer enables the new ones those will automatically stop working.
Post #244257 Thu Dec 03 2009 3:59am
k11ngc
thanks guys. reprograming DEALER ONLY
Thanks guys just got off the dog & bone and a nice freindly auto locksmith informed me not to waist my money by buying a key on ebay.......ONCE A KEY HAS BEEN USED ITS NO GOOD AFTER THAT ... ITS A ONE HIT WONDER!!! and no locksmith can reprogram a 2006 R R S key ...so its of to the stealers ... Just like you guys have said DEALER ONLY JOBBIE..
THANKS TO YOU ALL!!! FOR INFO Stephen Hughes
Post #244333 Thu Dec 03 2009 7:17pm
