![]() | Home > Technical > Sinking Overnight |
Although they reset the sensors it is usually a sensor problem, get them to replace the sensors. 2005 Zambezi TDV6 - Gone but not forgotten
ASH555 Member Since: 02 Dec 2006 Location: East Yorkshire Posts: 750 ![]() ![]() ![]() |
I had the same problem shortly after taking delivery of 56 plate, sensors changed and no further problems |
KiwiRRS Member Since: 22 Aug 2007 Location: Wellington Posts: 92 ![]() ![]() |
The front dipped overnight on my 07 TDV6. After resetting the ride heights and checking the sensors, it still settled in the front end. It turned out to be a faulty valve that required replacement - all done with out hassle, but a few days without the car as the dealer wanted to have it overnight to replicate the problem. |
RonnieG Member Since: 16 Mar 2008 Location: Armagh Posts: 207 ![]() ![]() ![]() |
mine now drops at the rear going in on Monday for new sensors. are these under warrenty? is it the height control sensor or which one? |
x5pea Member Since: 03 May 2007 Location: Lanarkshire Posts: 2097 ![]() ![]() ![]() |
nothing to do with the air leaking?? Common on the after market kits ive used |
No mate no leaks you can actually hear the valve opening to let the air out then closing off. My money is on the height sensor is either faulty of not reading properly due to a bit of dirt etc. |
