Home > Technical > multiple problems need help! |
The doc Member Since: 31 Oct 2006 Posts: 1173 |
Firstly I'm sorry to hear of your woes.
Sun Nov 22 2009 10:18pm |
Ilkeston Gym Member Since: 21 Nov 2009 Location: United Kingdom Posts: 5 |
Hello Ilkeston Derbyshire. |
Mon Nov 23 2009 7:23pm |
Texstar Member Since: 27 Aug 2006 Location: W.London Posts: 208 |
The window switches aren't the most robust in the world, I'd try replacing that next. Misfiring, you could try some injector cleaner in a few tankfuls of fuel to see if it helps. Has the fuel filter been replaced recently?If not, that may be worth doing. Sorry can't help with the other problems I'm afraid. Did you buy this with any kind of warranty BTW? RRS TDV8 Buck Blue (no, not now in my dreams). ..........D3 TDclankety clankV6 ............BMW 318i |
Mon Nov 23 2009 8:36pm |
MAW Member Since: 06 May 2006 Location: Lincs Posts: 3104 |
What is your mileage |
Mon Nov 23 2009 9:35pm |
Its Done 88k,bought with no warranty. |
Mon Nov 23 2009 9:40pm |
2nd Rower Member Since: 12 Nov 2007 Location: Upside Down Posts: 1382 |
Could the judder/misfire be the infamous stuck egr valve? |
Mon Nov 23 2009 10:21pm |
had trouble code for ns egr valve in it when purchased,thats now been done.but problem still there.knocking suspension heavy knock seems to be coming from rear of car. |
Tue Nov 24 2009 2:55pm |
Endjin Member Since: 22 Jun 2007 Location: Aberdeenshire Posts: 2087 |
Blimey - Sounds like you've got a bit of a Lemon
Tue Nov 24 2009 3:36pm |
Pelyma Member Since: 28 Sep 2005 Location: Sussex Posts: 1497 |
Speak to 10forcash on the Disco3 site. He is a mobile mechanic with autologic and lives your way. He is very good at these sorts of problems. Porsche Cayenne S Diesel 66 Plate |
Tue Nov 24 2009 4:04pm |
alid32 Member Since: 30 Oct 2009 Location: Lancs Posts: 12 |
I had a similar problem on mine, changed both EGR valves and the fuel filter... seems to have sorted it
Tue Nov 24 2009 7:13pm |
Just an update on multiple problems,window fault was osf window switch,sat nav dvd driver faulty aswell!After speaking to an auto gearbox chap he seems to think the torque convertor is faulty with regard to misfire/juddering up hills.Going to see him to roadtest it after bank holiday.Sounds expensive!!!! |
Tue Dec 29 2009 3:54pm |
