![]() | Home > Technical > 2010 Seat Adjust |
ScuderiaRR Member Since: 11 Nov 2009 Location: Bigfork, MT Posts: 18 ![]() ![]() |
Not sure if this is a unique problem. I recently purchased a 2010 Nara Bronze HSE Lux RRSport. The driver's seat does not automatically adjust when opening the door to exit the vehicle or when closing the door to start the vehicle. A RRSSC that I test drove did do this.
Kilovolt Member Since: 26 May 2009 Location: South Derbyshire Posts: 50 ![]() ![]() ![]() |
As a suggestion, have you made sure you have adjusted the seat to your preferred settings, with the key in the ignition and the engine running, and then saved those settings using the MEMORY buttons which are also located on the side of the seat?
I've tried that without success. Wondering if it's even supposed to have this feature. |
Not to give you a bad day but our RRSport 09 model had to have a new seat memory module (within weeks of delivery) as we could not get these functions working at all |
Supertrotter Member Since: 10 Mar 2006 Location: Brrrr.... guess where :o( Posts: 9905 ![]() ![]() |
Aren't the memory buttons on the door on MY2010? Runner up - 2009 Best Avatar Award |
949BFN Member Since: 16 Apr 2007 Location: Bloemfontein Posts: 59 ![]() ![]() ![]() |
Does this help?
Stealer trip then... Runner up - 2009 Best Avatar Award |
