Home > General > RRS 2010 and iPhone
Jimmy_75000
RRS 2010 and iPhone
Hi All,
just a quick question....I would classify myseflt as good with computer and gizmos but after different try, I have an issue with my iPhone and the RRS 2010 system... When I answer a phone from either the steering whell or the touch screen of the car, the call is indeed answer but the audio is not switch to the car system but stay on the iPhone... I have to then manually select on the iphone the car system for the audio....
Obviously, I have reset the connection and all....
Other with the same issue Question Range Rover Vogue ‘17 TDV6
Gone: Range Rover Vogue '11 4.4TDV8, Range Rover Sport ‘59, Range Rover Sport ‘56
Post #243155 Thu Nov 19 2009 10:13am
Lookers Park Royal
New one on me Jimmy. Mine works fine, therfore must be an issue with the phone or the car. You say that you have reset everything. My suggestion would be to delete all paired devices from the phone, sync with iTunes, re pair and then see what happens. Failing that then the nasty stealer that sold you the vehicle will need to have a look! Whistle
Let me know how you get on!
James Thumbs Up
Post #243159 Thu Nov 19 2009 11:08am
Jimmy_75000
James Thumbs Up
Laughing don't be so harsh on you Cool
I did deleted all the paired items on the phone and re paire with the car...no luck yet..When I have time, will redo a clean install of the phone firmware and will see...
Thanks! Range Rover Vogue ‘17 TDV6
Post #243161 Thu Nov 19 2009 11:37am
Gazzer
Mine is the same, seems to be about 50:50 of occasions. Seems tghe problem is with the iphone as that is the one asking whether I want the phone or car to talk.... 2010MY Land Rover Freelander 2 HSE
Santorini Black with Ebony Napoli Leather
Post #243171 Thu Nov 19 2009 12:44pm
Jimmy_75000
I agree with you....definitly sounds like an iphone side issue Range Rover Vogue ‘17 TDV6
Post #243173 Thu Nov 19 2009 1:10pm
umbertob
United States 2006 Range Rover Sport 4.4 V8 HSE Chawton White
This has been reported by several owners on rr.net as well when using the 3GS version of the iPhone on AT&T's network here, so it's not just you...
The compatibility list on LRUSA's web site says the iPhone 3GS is "NOT RECOMMENDED - The audio is not always routed to the vehicle system when accepting a call using the vehicle system." I didn't enter a specific VIN, but it definitely seems to be a known issue. Hopefully something that will be resolved by Apple with an upcoming fimware update for their phone.
Post #243187 Thu Nov 19 2009 5:54pm
Landlord
United Kingdom 2010 Range Rover Sport 3.0 TDV6 HSE Alaska White
Hope the upgrade is soon. 10MY arrives 20 December and would like my 3GS to work as it should, worked ok with 07MY. MY10 TDV6 HSE, Alaska White, Ebony with Contrast, Park Heat, Paddle Shift, Privacy, Heated Steering Wheel, Extended & Premium Leather,
MY07 TDV6 HSE, Zermatt Silver, Gone
1964 Austin Healey 3000
2007 LR Defender
2011 VW Tiguan R Line
Post #243201 Thu Nov 19 2009 9:25pm
merwiz
In my experience, if i use the phone to answer, i.e swipe on the touchscreen on the phone, then the phone takes the call.
If i use the Bluetooth device to answer, i.e the headset or in this case the car, then the device gets the audio.
I ALWAYS forget and use the phone to answer and end up having to move the audio to the headset, or car! I keep telling myself 'It's a toy'
But I've broken quite a lot of toys in my time.....
Post #243218 Fri Nov 20 2009 11:07am
Lookers Park Royal
I must admit that I've not had any issues with 2010my BT functionality with my 3Gs. I leave the phone in my case and just use the touch screen to access the numbers and the make/answer buttons on the steering wheel.
I checked if my version was the current one (which was something like 3.1.2 or similar) and it says it's the most up-to-date.
Hope it sorts itself, but it may be worth taking <erwiz advice and only use the car controls so as not to confuse the phone?
James Thumbs Up
Post #243240 Fri Nov 20 2009 3:38pm
