Home > Technical > Blackberry pairing with MY10 RRS
SilverspeedRRS
United Kingdom 2012 Range Rover Sport SDV6 Autobiography Sumatra Black
I have a Blackberry Curve and it paired with my car first time no problems however it doesn't show the address book correctly just shows two lots of numbers and no names? Any thoughts?
Post #239329 Wed Oct 07 2009 2:38pm
BKHK
My new Blackberry Curve 8900 paired fine with my MY09 RRS even though a VIN check on the LR website said that it wouldn't transfer the phone book....it did.
Sorry, don't know about the MY10 RRS system. Gone - 2008 Stornoway Grey RRS 2.7 TDV6
Post #239330 Wed Oct 07 2009 2:44pm
Pelyma
Buy an iphone Laughing Wink Porsche Cayenne S Diesel 66 Plate
Post #239467 Thu Oct 08 2009 2:45pm
cheesy
United Kingdom 2010 Range Rover Sport 3.0 TDV6 HSE Bali Blue
Hi SILVERSPEEDRRS I've got Blackberry 9000 and same happens to mine and tried all sorts but no good!!!
Cheesy
Post #239489 Thu Oct 08 2009 7:22pm
JeffW
United States
My Blackberry 9000 worked great with the 2010. The phonebook entries look fine. I had upgraded the blackberry to the latest OS, though, which I think may be the trick, because I read that was necessary in the case of the LR2/FL2, which uses the same (or similar) system. At the time, my carrier (AT&T) didn't have the latest OS available, so I just downloaded from a carrier from China. Works great. I'm currently at 4.6.0.282, but i think there are even later versions now.
I'm not up to speed on the OS versions for the Curve, but I bet all you need is an OS upgrade. The crackberry forum is good place to go to see what's available, how to do it, and how stable it is.
Post #239520 Fri Oct 09 2009 2:19am
Matt_RRS_baby
got the same issue with mine so will give the upgrade a go.
da missus ad an issue with her Audi and the dealer said transfer all the numbers to the sim and it worked.
will let you know if the same works on my curve - when i can fiure out haw to use the darn thing
Post #239662 Sat Oct 10 2009 7:53pm
JonnyDangerous
Hi all. First post on this forum after picking up my 2010 RRS. Everything great so far but have the same problem in that i have a blackberry curve which connects fine but the phone book doesn't show the names, only the numbers. Land Rovers web site does state that there are problems with the phone book. Has anyone managed to get the phone book to load correctly?
Post #242941 Mon Nov 16 2009 5:16pm
rrsowner
United Kingdom 2010 Range Rover Sport 3.0 TDV6 SE Stornoway Grey
Had the same problem with MY2010 SE and Blackberry 8900. After poking around a number of user forums it seemed that the problem was with the handset which was running on Orange modified software platform. RIM came up with a new version of the operating software (notified by running Blackberry Desktop software upgrade check) and once this was uploaded to handset (again using Blackberry Desktop software) phone book names and phone numbers transferred no problem. RIM software version is: v4.6.1.310 (platform 4.2.0.127). Hope this helps. Long suffering RRS Owner, but I can't help it!
Post #246511 Wed Dec 23 2009 7:14pm
JonnyDangerous
Had the same problem. The BB OS upgrade solves the phone book name issue. Search my name on previous posts as i sent the link to the BB OS upgrade page.
I'm still having one problem though. When a new call comes in i only see the number on the screen and not the name the number is connected with. Does everyone else have this problem?
Post #246536 Wed Dec 23 2009 10:37pm
