Home > General > IM FURIOUS! HELP ME TO COMPLAIN!!! |
flight Member Since: 24 Jan 2008 Location: London Posts: 186 |
Maybe this would be a good idea????
Fri Nov 13 2009 11:50am |
XXXAngelXXX Member Since: 03 Mar 2006 Location: Krautland Posts: 10894 |
the on-board tools s*** we all are aware of this
Fri Nov 13 2009 12:02pm |
Supertrotter Member Since: 10 Mar 2006 Location: Brrrr.... guess where :o( Posts: 9905 |
I changed all 4 wheels when Stormers arrived using the toolkit in the boot.
Fri Nov 13 2009 12:19pm |
2nd Rower Member Since: 12 Nov 2007 Location: Upside Down Posts: 1382 |
Mine broke in exactly the same way... All of the kit LR supply for changing wheels is useless, the brace, jack etc! |
Sat Nov 14 2009 7:18am |
So????
Sat Nov 14 2009 9:57pm |
ELD70 Member Since: 19 Jan 2009 Location: UK Posts: 163 |
Land Rover Customer Services.
Sat Nov 14 2009 10:44pm |
DrLex Member Since: 21 Nov 2005 Location: Ciderspace Posts: 257 |
Or write (recorded delivery) to:
Sun Nov 15 2009 9:28am |
lespes Member Since: 16 Jun 2008 Location: Channel Islands Posts: 1052 |
Would these not be covered by your warranty or are they only meant to be used once and then disposed of |
Sun Nov 15 2009 7:37pm |
npinks Site Moderator Member Since: 26 Nov 2007 Location: Watching Posts: 6716 |
the problem been with that is you have all the other bolts to undo before you can take the wheel off I can't understand why RRS have them like you do, FL2 have normal steel cast ones |
Sun Nov 15 2009 8:42pm |
The doc Member Since: 31 Oct 2006 Posts: 1173 |
Try "voice of reason" on here - WARNING he may tell you that you should have bought a "real RR" to get a functioning wheel brace. |
Sun Nov 15 2009 9:14pm |
Yes mine was replaced under warranty. Although I now carry my trusty 20 years old cast steel wheel brace in the rear. With the LR Range Rover Sport brace you either break it, or break yourself trying to release the nuts.. So it will never be used again, but I have it in the car for completeness for whenever I eventually sell it. And before someone says, if the nuts are set to the correct torque blah blah blah - these wheel nuts were tightened by the dealer... I even had a later case where Melbourne Land Rover (MLR) had tightened the nuts so tight that neither I, with my cast steel brace, nor Land Rover Assist with a very long extension piece, could get the nut off. It had to be taken back to Melbourne Land Rover (MLR) to be released. They never told me how they did it without having to drill the nut. A new jack is high on my list of wants.. |
Sun Nov 15 2009 11:21pm |
Lateral5 Member Since: 07 Jun 2006 Location: Down south Posts: 331 |
Love it.....it crossed my mind as well, only problem is I don't have enough real estate on the car to cover all my problems RRS TDV6 Bluetooth, VR, Roof |
Tue Nov 24 2009 10:09am |
Perhaps we could do a convoy.....that would be even better for business! RRS TDV6 Bluetooth, VR, Roof
Tue Nov 24 2009 10:13am |
Happy to arrange something if your down in Melbourne Lateral... I'm close to doing it anyhow! |
Tue Nov 24 2009 10:42am |
