Home > Technical > Air Suspension fault warning indiactors |
ELD70 Member Since: 19 Jan 2009 Location: UK Posts: 163 |
Could just be a height sensor on the way out or possibly a corroded connection somewhere. A dealer should be able to pull the codes up to give an idea of the fault. |
Fri Oct 30 2009 6:22pm |
Cavham Member Since: 30 Jul 2009 Location: Berkshire Posts: 91 |
thanks for the reply, I thought that but is was the fact the suspension went that made me not so sure. Getting a check over the car by and independant and then will get some idea. |
Sat Oct 31 2009 6:06pm |
Kilovolt Member Since: 26 May 2009 Location: South Derbyshire Posts: 50 |
More insight here for you............. been discussed much before
Sun Nov 01 2009 11:59am |
The doc Member Since: 31 Oct 2006 Posts: 1173 |
Could be a faulty level sensor happend to my car when it was brand new and 670 miles.
Sun Nov 01 2009 6:37pm |
