Home > Technical > Removal of Instrument pod
clannick
2008 Range Rover Sport TDV8 HSE Stornoway Grey
Does anyone have the technical diagrams and instructions to remove the instrument pod. I need to change the kph for mph speedo dial. Thanks
Post #241631 Sun Nov 01 2009 8:50am
no_one_has_this_name
its easy pull your sttering wheel all the way out and down, take column shroud off 3 screws and the exposes the 2 screws that hold the clocks in (two white brackets) take screws out.
then get clocks out easy, but remember YOUR CAR WONT START WHEN YOU FIT NEW CLOCKS AS THE IMMOBLISER CODE TO MATCH KEY IS IN THE CLOCKS (BLAME FORD FOR THIS) "ha ha HA HA" laughing all the way to the bank!
Post #242607 Thu Nov 12 2009 10:50am
bomber1
2006 Range Rover Sport TDV6 SE Zermatt Silver
update
hi
did you manage to get this sorted out as I am in a similar position.
was it the fill unit you changed or just the fascia for the clocks?
Bomber
Post #245280 Sun Dec 13 2009 2:17pm
