Home > Technical > Characteristic Resonance
2nd Rower
Australia 2008 Range Rover Sport TDV6 HSE Chawton White
Has anyone who owns a 2.7 TDV6 been infomed by their dealer or Land Rover that there is a characteristic reasonance through the steering wheel between 1600 and 1800 Rpms??
Post #240299 Fri Oct 16 2009 4:29am
islider
United Kingdom 2006 Range Rover Sport TDV6 SE Java Black
Hmmm, kind of yes.
I have a resonance from 1600 rpm upwards, was told it's a characteristic from 20' wheels.
Are you on 20's?
But characteristic is usually the answer to anthing I point ot while it still works. Then when it gives up, they find the problem and replace it.
Prevention is better than cure is something they don't seem to understand. Confused
Post #240397 Fri Oct 16 2009 7:41pm
redrover
Australia 2007 Range Rover Sport TDV6 HSE Java Black
Re: Characteristic Resonance
Yes, and I believe you have seen my thread... http://www.rrsport.co.uk/forum/topic15455.html
That resonance is still there in a slight form and I believe may be the transfer box. I will make sure the dealer is aware before it goes out of warranty. Or maybe it's just a "characteristic" Confused TDV6, MYO7 Java with Ivory leather, 19 inch wheels
Post #240409 Sat Oct 17 2009 12:17am
redrover
Does it occur under load? TDV6, MYO7 Java with Ivory leather, 19 inch wheels
Post #240463 Sun Oct 18 2009 9:13am
