Home > Technical > 2010MY Rear Seat Entertainment |
umbertob Member Since: 22 Sep 2005 Location: Pasadena, CA Posts: 944 |
My 2006 with RSE did include a remote control for rear passengers to control playback on each headrest monitor. I can't imagine the system on MY2010s would be much different than mine (in this day and age we are still stuck using wired headsets, that sucks.) On the 2006 version, you need to flip a switch under the remote to select control of either left or right rear monitors, and need to point the remote directly at the selected rear monitor for it to work - the infrared beam on the remote is highly directional. Also - sorry if I state the obvious here - are the batteries in the remote fresh, and is the remote enabled from the front touchscreen? On my 2006, one of the things you can disable from the front "supervisor" RSE menu is the remote operation, in case it falls in the hands of unruly kids back there (you can also limit volume level over the headphones or mute them entirely, so the little brats don't also go deaf.) Although the graphics may have changed, I bet there is some sort of similar override on the 2010 version. |
Sat Oct 03 2009 9:11pm |
SingeRRS Member Since: 22 Sep 2009 Location: Garage Posts: 127 |
Umbertob - thank you very much for the detailed description. The RSE system sounds identical from your description - I did renew the batteries as I don't trust the dealer not to take a shortcut as far as I can throw them!
Sun Oct 04 2009 8:27pm |
