Home > General > 2010 RRS Low Coolant Level |
PJPR01 Member Since: 12 Mar 2006 Location: Houston, Texas Posts: 355 |
...hard to believe that 4 years later, this issue is still popping up after the TSB which fixed it on earlier models.
Mon Sep 28 2009 2:09pm |
umbertob Member Since: 22 Sep 2005 Location: Pasadena, CA Posts: 944 |
Early adopters beware... The GTR is lighting up like a X-Mas tree with all kinds of special service messages affecting MY2010s. Not a good sign, for sure. Among the many SSMs, here is one regarding the coolant tank issue you are experiencing:
It would be nice if, for once in its storied history, Land Rover did its homework on new models BEFORE releasing them to dealers... |
Mon Sep 28 2009 7:22pm |
islider Member Since: 19 Jun 2009 Location: Deepest Darkest Hedgeland Posts: 457 |
Agreed, some teething problems are to be expected.
Mon Sep 28 2009 7:32pm |
RRS808 Member Since: 28 Sep 2009 Location: Honolulu Posts: 3 |
Thanks for the comments everyone.
Mon Sep 28 2009 8:40pm |
They will likely replace the coolant expansion tank (which contains the floating switch) with a new one, as directed by the above service message. Hopefully the replacement sensor will not develop the same issue. "Under Investigation" means Land Rover doesn't have a clue yet as to what may be causing this issue, so... You are now unofficially a Land Rover beta tester. Best of luck and keep us posted on the outcome! |
Mon Sep 28 2009 8:57pm |
Just picked up my RRS and everything is great again.
Tue Sep 29 2009 12:59am |
