![]() | Home > Maintenance & Modifications > BOBBLES! Not looking good - Rear N/S shock has collapsed.... |
Supacat Member Since: 21 Feb 2009 Location: West Yorks Posts: 497 ![]() ![]() ![]() |
Are you parkng the car on even gound? If you are then the the different gap under each wheelarch should mean that the whole of the car looks lopsided when viewed from the front or rear. Is this the case also? If so it may only mean that the calibration of one of the senors it out or that there may be a leak in one of air suspensions units. Either of these are a relatively painless fix if the car is still under warranty.
Ride height sensors are a popular item to fail... and simple to replace. If the car is under warranty still, take it along to the dealer and have them sort it out |
