![]() | Home > Maintenance & Modifications > Drivers door seal worn away and split in 18 months |
ChrisP Member Since: 26 Jan 2008 Location: Derbyshire Dales Posts: 1392 ![]() ![]() ![]() |
Just taken my car in to have 4 wheel tracking done and asked them to replace the drivers side rubber door seal under warranty as it is worn away and spit.
It's not the supplying dealer,I'll try them next.
Misery Member Since: 07 Dec 2005 Location: Waiting for L405 Posts: 2555 ![]() ![]() |
I had this problem as well and my dealer said the same thing. Went to another dealer and he said no problem I will say it is split. Keep on trying but it's not all bad the part is only £24.00, I know that is not the point. |
islider Member Since: 19 Jun 2009 Location: Deepest Darkest Hedgeland Posts: 457 ![]() ![]() ![]() |
ChrisP
Hi Misery,
Chrisp
Thanks for the feedback guys.
Good Luck with the shimmy, hope they don't tell you it's within tolerance like they did with me.
Got my car back but need to check it at motorway speeds to access if it is better.
