geezo
FUEL PROBLEM...HELP ASAP PLEASE | |
TDV6 2006... Changed fuel filter as there was sediment in tank, this was causing fuel starvation(power loss)... In my lack of knowledge at time , i was not aware of purging method...started engine, cut out afer 20sec.. Cranked engine in hope of lifting fuel up,, battery eventually flat...
Battery now fully charged, tried purging fuel up, nothing... Put ignition pos2 with bleed valve off...nothing.. I cannot hear fuel pump kickin in... relays seem ok, fuses good.... fuel in tank 212miles remaining..
Fuel lines from top of engine to filter are ok... Is it pump, or have it shutdown because i cranked it to long??
1 am i right in believing ECU can be reset to solve problem??
2 Where,s the pump
3 Does anyone know what it coul be... and what to do..
Be much appreciative... am desperate as we going away on weekend
Thanks guys RRS HSE 06
M REG LANDCRUISER
Audi TT Quattro s/tronic convertible 2008
Range rover Vogue 3.2v8 2007..
Thu Sep 10 2009 5:43am |
