Home > Technical > REDUCED ENGINE PERFORMANCE??????
sadmadbad
Czech Republic 2008 Range Rover Sport Supercharged Java Black
REDUCED ENGINE PERFORMANCE!!!!!! Big Cry
I HAVE JUST REBUILT THE FRONT OF MY S/C 4.2 2008,EVERYTHING IS FINE UNTIL I GIVE IT SOME THEN THIS MESSAGE APPEARS AND THE CAR GOES INTO LIMP MODE????? I THEN GO TO GARAGE COMPUTER SAYS NO FAULTS , THEN I DRIVE NORMALLY NO PROBLEM,BUT AS SOON AS I GIVE IT SOME MESSAGE APPEARS REDUCED ENGINE PERFORMANCE !!!!!!! ANY IDEAS ,ANY SUGGESTIONS Big Cry
Post #236291 Fri Sep 11 2009 7:41am
BKHK
WHAT DID YOU DO TO THE FRONT WHEN YOU REBUILT IT? WHY DID YOU REBUILD IT? Shocked Gone - 2008 Stornoway Grey RRS 2.7 TDV6
Post #236292 Fri Sep 11 2009 7:47am
sadmadbad
I HAD TO FIT A NEW WING ,BONNET AND HEADLIGHT,ALSO RAD PACK HAD A LOW SPEED SHUNT ,NO STRUCTUAL DAMAGE, THIS IS ALL CAR HAS NO FAULTS ON DASH ,OR COMPUTER ????
Post #236293 Fri Sep 11 2009 7:49am
I'd suggest the ECU needs looking at - maybe replacing or reflashing. It might not be obvious to the eye, but maybe the ECU got damaged in the impact. Everytime you give it some beans, the ECU spuriously sees a failure event and goes into limp home mode.... this "garage" you've taken it to, is it a LR dealer?
PS: no need for CAPS, we don't need to be SHOUTED AT! Very Happy Thumbs Up
Post #236294 Fri Sep 11 2009 8:10am
sadmadbad
hi m8
the garage is not a L/R and has only a bosch hand held computer,i live here with my wife im originally from london i am mechanic minded and understand what your saying, but i agree that the fault would be etected on a genuine L/R computer/diagnosis machine,i was thinking about the air intake and the control valve/compressor which pushses air into the engine???
Post #236300 Fri Sep 11 2009 8:23am
Realistiically, it could be any number of things but best to get it into a LR shop (or at least an LR indy if you can find one) but not sure if you'd have to travel miles to find one in CZ?
Post #236301 Fri Sep 11 2009 8:37am
Leo
Kenya
Do a search on here, for "Reduced Engine Performance" - it is a well known issue with the supercharged 4.2 and there is an easy fix. I think it's to do with the fuel pump, but don't remember.
Post #236363 Fri Sep 11 2009 3:01pm
sadmadbad
THANKS ALL !!!!!!!
Very Happy
ALL SORTED NOW GOES LIKE SCALDED CAT !!!!!!!!!!!!!! Thumbs Up Very Happy
Post #236635 Mon Sep 14 2009 4:48pm
Shauny0809
Hi mate wat was ur issue with the car and how u fixed it as mine keeps going on reduce proformance and won’t rev past 3k revs and has missfire thanks
Post #558068 Sun Jun 03 2018 8:27pm
Shauny0809
And can u hear hissing noise on ur engine near the pcv valve as I’m new to these and sounds like a leak but if u presss on top of the circle pcv valve it stops hissing
Post #558069 Sun Jun 03 2018 8:30pm
geoffsnook
I would have thought it was the Aux suoercharger pump being wired the wrong way as its a known fault with them i changed mine for the same reason Thumbs Up
Post #558088 Mon Jun 04 2018 7:27am
Shauny0809
I’ve got recipts for it being changed at landrover on mine so not sure if will be that would the pump cause missfire thow it said on recipt changed wires and fitted new pump
Post #558095 Mon Jun 04 2018 8:07am
geoffsnook
if yours has had it changed then it will not be that you got any codes shauny from it Thumbs Up
Post #558099 Mon Jun 04 2018 9:21am
Shauny0809
Just misfires 2468 I think was the person who I bought it off cheap said it ran out fuel on its mot and ever since that it not ran properly when ur driving it it won’t really go over 3k revs so u aft to put ur foot slightly on the pedal and u can achieve up to 50mph but u can feel the car like bucking we’re its like pulling back forth like it wants go but being held back also some days u can put ur foot down abit off the start and gets up to 40 straight away but then will do same again and u get engine light flash it’s thow it’s like running out fuel feeling I’ve changed spark plugs weekend had it terraclean weekend changed coil pack on 1 of them as it’s been changed before so fort might been dud 1 I’ve just orderd pcv valve as it’s hissingg and if u push down on the circle valve on the plastic it stops so dunno if that leaking So fort I’ll try that but part not come yet I was thinking of changing the fuel pump and filter next incase the fuel pump is faulty or fuel filter blocked in tank
Post #558101 Mon Jun 04 2018 9:57am
geoffsnook
Get someone with an IDD tool to get codes or nanocom if we have codes it is a bit easier to help you it could be an air leak but does sound a bit more like a fuel issue but without codes you will be changing things maybe when they don’t need to be done Thumbs Up
Post #558102 Mon Jun 04 2018 10:02am
